Assuming you're talking about Harry's Cafe de Wheels, it's easy to find...
If you're heading in there via the city and using William Street, take the "exit" on the left which brings you up to where the famous "Coke sign is. From there, turn left and drive straight thru Kings X, past all the clubs and stuff, and follow it around to the left past the Bourbon & Beefsteak Bar/Restaurant. Around about 400m or so down from that, you'll see that the road gets really narrow and really windy. Keep your speed down or you'll probably understeer straight into the oncoming traffic. When you reach the bottom of the windy stretch (it's not very long) you'll get a set of traffic lights and see water in front of you, and probably a few Navy boats. Turn left at these lights and you'll see a big Shell servo, and a bunch of people standing outside some old caravan, which is Harry's. It's almost always busy there, so you can't miss it!
Enjoy!
https://www.sau.com.au/forums/topic/8323-where-is-harrys/#findComment-120326
Yep it's a great place for a feed and you can almost guarantee there will be plenty of cruisers out every night of the week.
Just be careful with them chilli dogs... the snags tend to get pretty slippery, make sure you keep em in the bun unless you wanna attract some embarassing attention :uh-huh: (not that i'm speaking from experience or anything :thumbsup: )
https://www.sau.com.au/forums/topic/8323-where-is-harrys/#findComment-120986
Originally posted by ndr
Great,,, thanks for that Ed,,,I really needed to hear that,,,,. You just turned me off goin back. I liked the Hot Dogs,,,maybe I'll just get a packet of chips from the servo next time....
Neil.
haha don't be put off...i think that's why they taste so good? :D
but seriously I did see one...so buyer beware :uh-huh:
https://www.sau.com.au/forums/topic/8323-where-is-harrys/#findComment-121073
Yea and next thing your gonna tell me is you seen that little pimple headed bastard spit on my Filet of Fish at Macka's cause he hates white Skylines,,,,.
I'm taking Sandwiches from home next time I cruise....LOL's
Neil.
https://www.sau.com.au/forums/topic/8323-where-is-harrys/#findComment-121077
And does anybody know what the name of the street is?? :mad:
we stopped in on new years eve and were talking to some pommy tourists who needed to know .... and not one person, inlcuding the staff, knew the name of the road LOL :D
by the comments above, i'm glad i just got coffee :eek:
although that was pretty shit too
https://www.sau.com.au/forums/topic/8323-where-is-harrys/#findComment-121119
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
