so how many people that play GT4 have actually completed the nurburing 24 hour, and whats the prize car for winning? i assume its oe of those gt4 F1 cars so you can complete the F1 championship??? im hoping it is anyways coz otherwise im stuck tryna win that F1 championship coz none of the cars on gt4 can beat them lol.
https://www.sau.com.au/forums/topic/83484-gt4-nurburing-24hour-endurance-race/
yeah i did it but u dont win a F1 car...
its pretty easy.... u dont even have to do it urself... just get a lap ahead and leave the car in auto mode til its done. gets the driver good experience too so u own them in auto mode.
did it with the nissan 350z prototype race car
yeah... there are 3 24hour races, 1 at the ring and 2 at sarathe...
For the Nurburgring race i just used the toyota minolta cv-88 (i think thats it's name) and put it in B-spec.... came back to it 24hours later and had an extra $1.sumfin million plus a spanking new F1 car....
inark, what did you win??
yeah i was plannin to do it in B Spec, f*** stayin awake for 24 hours doin the race lol, thats insane. what did u guys do about the tyre wear thing but??? coz u'd have to pit in n stuff yeah???
and yeah there is 3 24 hour races, one on nurburing 2 on sarthe, INARK mb u did the nurburing 4 hour race by mistake???
lol, did you never wonder what B Spec was dude??? its ezy, its for us lazy people who cant be f**ked racin at times, all you gotta do is tell the virtual driver when to overtake and pit in, apart from that thats it, and it works the same way as if you win the race, its great. the only races you cant do it for are the special ones like the rallies.
the b-spec driver pits automaticly when the tyre wear hits red so you get a tyre change and refuel at the same time.
oh really, awsome i didnt know that one. well im 2 hours 32 minutes into it so far, F1 car here i come :)
  • 4 weeks later...
3x faster in b spec so it's "only a couple of hours"
lol, 8 hours of sitting infront of ps2 is still more than a couple..... especially when every 10min or so you gotta put it back on to x3 speed.
i agree it sucks how its constantly day light though...
GAY!! why didnt i get a F1 car... how shizer lol
i havent played in MONTHS so i will check what i won when i get home... omg so owned
so what did you win then????
I get into a rut of not playing, then when I start up again I play regularly :lol:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
