I'm wanting to upgrade my injectors because I think mine would be maxing out about now. I have a RB25, exhaust,fmic,fuel pump, pod, haltech E6K, hi-flowed hybrid etc. and it's making about 250rwkw on 12.5Psi.
I got told to get a set of Nismo 740cc injecters, should they be able to do the job fine keeping in mind I will be upgrading later on and wanting more power? Cheapest I have found is $810 delivered, anyone know anywhere to get them better?
Would a generic brand do just as good of a job?
One mroe thing, if I install them then plan on driving to the dyno shop to get tuned. Will the car still run right? Or would I cause some damage???
Sorry for all the Q's but I need to fnd out beforehand..
Cheers.
https://www.sau.com.au/forums/topic/83494-injector-issue/
I'm after injectors too, group buy doesnt seem like a bad idea
Cheapest I have found them so far is $890 delivered, from a Sponser of nissansilvia.com. He is in Tokyo so if you want to try and organise a group buy I would be in for it.
Sounds like I won't be able to drive to the shop then, I will have to try and figure out another way..
https://www.sau.com.au/forums/topic/83494-injector-issue/#findComment-1512336
what are the contact details of that guy who sells them for 890
https://www.sau.com.au/forums/topic/83494-injector-issue/#findComment-1513928
if the haltech has a "gross fuel map trim" function like most ECU's do (mostly used to quickly diagnose fuelling problems) then you can probably get away with trimming the whole fuel map by a factor of
370/740 = 0.5
and it should run OK till you get it to the tuners. just don't flog it on the way there!
https://www.sau.com.au/forums/topic/83494-injector-issue/#findComment-1514529
thats pretty cheap guys, is that the final price $810 del, or is there that possibility of being taxed by customs and gst ..... coz i went for some sard injectors with adapters for $1100.
i know nengun are selling the nismos for $940 but there is always that possibility of being taxed so i didnt bother and just payed the extra money to get the sards quicker and no more hiden costs...
https://www.sau.com.au/forums/topic/83494-injector-issue/#findComment-1514650
370/740 = 0.5
How would I do that?? Not too familiar with the Haltech..
Where did you get $810 delivered from? I thought it was $870 delivered?? And I'm guessing that would be including everything?
Any word from Nengun B33st???
https://www.sau.com.au/forums/topic/83494-injector-issue/#findComment-1515725
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
