hi guys
have to sell my dream car
interior is in vgc.As well as body. car is a 5spd manual and is black in colour
has 67000k's with books
ps,pw,ac
Engine
-RB20DET ECCS
-Turbine: HKS GT2530 HKSstrengthening actuator + HKSturbine outlet
-Injector: 444cc RB26 BNR32genuine
-Ignition coils:Split Fire SuperDirect Ignition System
-SparkPlug:HKS SUPER FIRE RACING PRO
-Cams:TOMEI PONCAM (IN:260° and EX260°)
-Cam Gear:TOMEI ADJUSTABLE
-HeadGasket:TOMEI METALHEAD GASKET 1.2mm
-Timing belt:NISMO
-CPU:APEX'I POWERFC (AP engineering make) +FCcommander
-Boost controller:HKS EVC3 ( everything is there except for the controller itself )
Oil catch tank:CUSCO. ( have just re-done the engine with all brand new hoses and a new T piece
-Motor oil:Castrol Formula RS (SAE 10W-50)
Inhilation system
-Air intake:APEX'I POWER INTAKE
-Air flow: Z32AFM genuine
-Intercooler:HKS INTERCOOLER KIT TYPE S
- Hks intake pipes
-Blow off valve: ARC
Exhaust type
-Front pipe:stainless steel dumppipe.
Into a twin 2 inch to cat
-Catalyst: NISSAN genuine
Muffler: HKS SUPERDRAGGER (BNR32) 4 inch from cat back
Drive system
-Diff.:NISMO GT L.S.D (mechanical cable type) 2WAY DIFF
-Gearbox:R33 RB25DET 5speed manual
Diff. oil:OBERON F808 (SAE 85W-140)
-Gearboc oil:OBERON F808 (SAE 75W-90)
-Tail shaft:JUN propeller shaft
-Clutch:ATS single carbon clutch
Exterior
-Light/write:R32square-hole
-Bumper:BNR32 GTR BUMPER BY TBO
-Mirror :Aero mirrors
-Side skirts and rear bar modifications
Brakes
-BrakesFront : S15 calipers
-RotorFront : S15 rotor
-BrakesRear : BNR32 twin piston caliper
-RotorsRear : BNR32 Cross Drilled
-Brake pad Front :ENDLESSCc-x(0 to 700 degree rating)
-Brake pad Rear : ENDLESSCc-x (0 to 700 degree rating)
-Brake fluid:ENDLESS Dot-4 BRAKE FLUID
-Suspention:Front CUSCO comp1 Rear :CUSCO comp LZero ( both are hight adjustable and brand new are 800 dollars a corner )
Wheels & Tyres
-Wheel:ADVAN SA3R F 17-8J +35 R 17-9J +38
Tire:F ADVAN NEOVA (AD07) 215/45R17
R BRIGESTONE GRID? 235/45R17
OTHERS
-Strut brace Front: CUSCO
-Strut brace rear: Cusco
-Stabilizer: Strengthening stabilizer (OEMcommodity)of air
-Tie rod:A31genuine
-Boost gage and oil temperature gauge:BLITZ BLM
-Audio:JVCKw-xz72da+
-alpinetweeter+
-BOSCHMANN speaker
-Rear finisher special light
-Trust Gear shift knob
The price is $17500 (negotiable) with compliance and rwc
cheers greg
any questions pm me or email me [email protected]
Edited by GTSR22
yeh i will,the car has no front bar on it atm becuause it is getting painted, so thats why i could only take shots like that, i have put one more rear shot in.
thanks greg
Very interested, will you consider tradding for a 97WRX stock ass plus cash adjustment? Its' for me mate otherwise give us a bit of time to sell the rex. Anyway email me so we can arrange something, [email protected].
Cheers
hey pretty interested... how long till the front bar is painted?? i'm in brissy so would like to see the front of the car before deciding to come look at it. if you've got photos with the front of the car re-painted, can you send them to [email protected]
email sent
Mate you've sent me email but you never give me your number, we're serious about it and emailing each other is not helping at all.
LOOK
http://www.skylinesaustralia.com/forums/in...showtopic=85959
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
