Hi guys,
Can anyone tell me if there is an advantage of using the AVC-R over the pfc bost control kit? I tried doing a search on this but it kept coming back with errors.
I was going to get the AVC-R, but dont know if there is any advantage in getting it, as it costs more than getting the boost kit for the pfc
Thanks for your help.
https://www.sau.com.au/forums/topic/83783-power-fc-boost-control-kit/
It uses the same boost control solenoid as the AVCR. I have the PFC boost kit and no problems with it.
is there anything that the avc-r can do that the pfc cant? apart from having a 1/2 din blue screen in your dash? :P
avcr has gear based boost control
avcr has rpm based boost control
whether those things are worth 200$ more or up to you
oh ok...the gear based boost control might be worth it. Being able to limit boost in the lower gears would be quite useful. Seeing as there is a heap of money going into making the power, $200 will be worth it to help limit wheel spin in 1st and 2nd gears :P
Cheers for that :)
thanks for the link ;)
I just tried to search again and got the same error:
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
The error returned was:
One or all of your search keywords were below 4 characters or you are searched for words which are not allowed, such as 'html', 'img', etc, please go back and increase the length of these search keywords or choose different keywords.
oh...i think I get it now. I guess it cant handle fc in the search criteria :P
I have the PFC boost control kit and it controls boost very accurately.
However, with the plan of a bigger turbo in the pipeline, I would probably have gone with the AVC-R so that I can limit boost in lower gears.
And although some people will say that I can limit boost with my right foot, and I've said it myself as well, it would still be VERY handy to be able to have control over the boost characteristics of the engine.
If anyone has an R34 and wants the PFC boost kit, I'll swap for an AVC-R. Cash adjustment of course.
Hey Bass, thats what I thought too. Being able to control boost in 1st & 2nd especially. I am looking at getting to 300rwkw so prefer something that will electronically control the boost.
I know I wont be able to trust my right boot :)
PS  Love the white writing on your tyres by the way,  very RACE!
Thanks man ;)
Takes a lot of time colouring in the writing with a paint pen :) In the photo I only did half on each tyre. Started getting too dark.
I'm sure if you were trying to reduce wheel spin in a certain situation and had the ability to do it electronically, you would.
I know I would.
Lower boost in 1st and 2nd gear is simplistic at best. Let me see if I have it right;
You run 1.5 bar in 3rd, 4th and 5th
But say 1.2 bar in 1st and 2nd
That way you will get less wheelspin in 1st and 2nd :D
But what if it is a nice warm day and the road is clean and it will handle 1.3 bar?
But what if it is raining and 0.8 bar is needed for less wheeelspin?
But what about if the road is sorta clean and has only a few bumps, so 1.25 bar would be good,
But what about if the road is a bit bumpy, and the tyres are getting old, and 1.15 bar is the go.
Do you limit the 1st and 2nd gear boost to 1.15, 1.2, 1.25 or 1.3 bar? <_<
What you need is traction control, not lower boost. And the best traction control is your right foot.
:) cheers :angry:
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
