  • Replies 520
Posted Images
Guest DIRTgarage
a little bit of a DEVIL Paul????
and has the other had its Jap engine fitted that the owner was talking about???
The "other" is nearing completion............I will be sharing a private test and tune day very soon with both of these cars............full competition prep too!
Ahh the urge to run 9's
Guest DIRTgarage
are both going to be ay Jamboree???? fingers crossed they are!!!!!
I envy you mate.... would love nothing more than to get the 200 out on a very good track and run 10's with it :cheers::D
Thats a negative on Jambo.....definately not going to be at Jambo
:D:(
Gonna have to get them to pay their cash up and get then to this test and tune then hey :cheers::D
Can anyone confirm what the go is with unregoed cars??? was thinking of bringing out the Mount Vincent Estates GTR but it doesnt have rego..... are we able to race and what needs to be done to get it on the start line???
I know John races the 300 but was thinking he must have a log book for it....
Edited by ido09s
Guest DIRTgarage
Check earlier in this and other threads.  Un-registered vehicles have to be tech-inspected prior to the event.
Adrian
Correct...also, the owner knows what is required, as the ANDRA officials spelled it out to him at last years Drag Combat
Guest DIRTgarage
thats all good then, in the workshop it stays :cheers::( ANDRA wont approve the roll cage apparently which is a shame, would have been great to get it out on the track and have som fun with it :D:)
Yeah....some of the ANDRA rules are archaic....that roll cage would rate amongst the toughest in aust
Edited by DIRTgarage
well ive never been drag racing cause i think its gay!
what can i say i must be camp
ive even rigged up a rexona can under the bonnet to get that 2rismo look at the line
deposit made!
ill be in the black 31 slagging off camp people
NATIONAL AUSTRALIA BANK LIMITED
Amount: 95.00
Description: fatzdragday
Remitter name: fatzdragday
Transfer date: 19/08/05
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
