Hi all.
I have a 2000 R34 GTT incoming and have just started thinking about number plates for when it arrives. After looking at the pics I have of it (standard body kit) I have no idea how/if I will be able to fit coloured (as in the blue ones) NSW plates to it as they seem to be much too wide and short for the plate space provided.
I trawled through the forums here with no luck finding a similar sob story so thought would be as good a reason as any for my first post and am hoping someone else has had to solve the same problem.
Cheers.
https://www.sau.com.au/forums/topic/83984-fitting-number-plate-to-2000-gtt/
The Front Plate on the S1 simply needs some spacers as you have mentioned. The Rear Plate is a perfect fit (with no space for anything else)
I have the Black on White NSW Plates... may be different for other plate styles!
The short height of the coloured plates will leave nasty gaps above/below on the front by my guesstimates. Might just wait til I go see it when it comes in and take a template of the plate size with me. Would really like the coloured plates but if need be, the NSW 2+3 letters/numbers white on black should fit nicely.
  • 8 months later...
looks nice
mind if i ask how much u picked it up for?
the plates should fit , might need spacers but yeah ^^
the space for the plate looks the same as mine and i have the big fat ugly yellow plates
Hi guys,
My nams is Michael and I'm rather new to the site. I own a 2001, R34 Skyline GTT S2 with the same factory fitted Nismo front bumper as user: ECL's car (or the photo being shown in ECL's signature). I really like the aftermarket addition of the lower lip at the bottom of the front bumper. Does anyone know where to get them or where i can source them from? the brand of it, etc? Thanks for your help in advance!! I've fallen in love with that piece of bumper lip and i can't sleep until i get them!! :D
cheers,
Mic
post-5240-1146727617.jpgpost-5240-1146727659.jpgI dont know if this is of any help to you but this is how i did mine, its a seriesII GTR.
Made small brackets for the front plate so it sits higher that original and out a bit, this way its not in the way of the cooler . The rear i used long bolts (60 mm) and tube spacers, if you dont use covers you only need small spacers ( 10 mm ), in my case about 25 mm spacers used to accomodate the cover .
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
