Just thought i might say i picked up my car from MRC 2 weeks ago, after getting a rebuild.
More than happy with the wrok carried out and the service privided by MRC in castle hill and i would highly recommend him to everyone here.
The pistons used were ACL mahle, and they are extremely quite. And the difference in the engine is astounding.
Although i have only done just over 1000km on the new engine, i would say he has done an excellent job with the car.
DK
https://www.sau.com.au/forums/topic/83997-back-from-rebuild/
Hi suspense. hows the running in process going? any other things to report about the rebuild? sorry about all the questions, i get my car back from a rebuild at the end of this week and im gathering all the info i can.
cheers
sam
cheers
sam
doing around 6000km's on mineral oil... @ stock boost levels.
apart from that dont thrash the shit outta it, and vary your revs a bit for the first 1000km.
From what Mark was telling me, I think it was around $6.5k...I'm not sure if that also included the hi-flow turbo???
Suspense will be able to clarify.
Depends what u end up doing really?
I ended up around the 8k mark, with hiflow turbo, and brass button clutch and what not
  • 1 month later...
What else was included in that?
Engine in/out?
Forged pistons?
What machining was done?
Enigne in/out, Forgies, Head was machined. blocc went i size over. brass button clutch, shot peened rodsmanifold machined abit, tomie headgasket... off the top of my head
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
