I would like to adjust the ride height on my coil overs, however I need a special tool which I was not given with the car and cannot seem to find at repco or bursons, does anyone know where I can get it from?
The nut that adjusts the height has notches in it, its not a typical one where you can whack any old adjustable wrench over! :P
https://www.sau.com.au/forums/topic/84033-top-secret-adjustable-coil-overs/
As a backyard butcher, I have done the following a couple of times.
Insert big screwdriver or prybar into lower ring on the left side of the shock. Wack with hammer. Voila ring is free to turn. Once the lower (locking) ring is free the top one should also move.
Tighten is the opposite of loosen.
haha yes I did think about it, however it looks like it is anodized aluminium, which me thinks would damage the sucker.
I however thought that to adjust ride height, I would have to tighten the lower one so the spring is more compressed or am I way off? I'd be very interested to find out!
Yeah you have to tighten them to raise the ride height. But it is only the top ring that controlls the height, the lower ring just locks it in place. So you unlock the lower ring then the upper one is free to turn, in this case tighten.
And yes they are aluminium, use "tap" not "bash" as the setting on the all purpose adjusting tool.
They are hardened aluminium and you can buy C spanners from CBC Bearings, there is one near you. Justmeasure the OD of the spring seat ring, that's the size C spanner you need. If it has a locking ring as well, then you will need 2 X C spanners, one for each ring.
:D Cheers :)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
