Hey Binky, sorry to interrupt with your quest for the offset... but is that a GTR front lip on your GTT? That is mounted to the standard bar right?
Where did you get it and for how much if you don't mind me asking...
Sorry to interrupt once again :P
I don't know the wheels offsets exactly but I know that wheels that fitted an R33 will fit an R34 properly.  R32 are different.
what did the wheels you are looking at come off?
Haven't actually bought them yet, still not sure if they will fit.
http://www.skylinesaustralia.com/forums/in...showtopic=83837
Meh, 18's suck!!
The Te37's on the GTR rub the arches front and rear, cost too much for rubber, have limited access to semi comp rubber and don't feel as good on the road. Too little tyre, too much wheel = harsh ride. They are also prone to understeer due to the amount of mass away from the centre of rotation.
I'd sell mine in a second for a decent set of 17's with enough cash adjustment.
I just had a look at the spare set of R34GTt wheels I have here and they are 225 from side to side on the tyre, so say 215, and 154 from back of tyre to mounting face so say 150. This would suggest 215/2=107 being halfway and 150-107=43. So about 40 offset.
The wheel markings are 17x7 1/2 JJ and another marking simply states 40 which could be the offset.
What the clearances are over the brakes I couldn't say.
+30 should fit fine. The standard GTT wheels are +40 and they sit way in the guards. +30 will see your wheels come out by another 10mm which is not a lot. I once tested a +22 wheel on my GTT and it pretty much sat flush on the guards. Just make sure they clear ur brakes :P
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
