Virtually brand new TO4e Turbo-charger. This item has travelled around 1000kms and is in excellent condition. The majority of the turbo is spotless with just a minor amount of carbon present in the exhaust housing. This particular turbo was fitted to an internally standard RB25DET and produced 298rwkw on 18 psi of boost. Be quick and grab yourself a bargain folks.
ID plate on comp cover-type HKS, T3V band, part no. TO4E and serial number is AO7100152.
One the comp cover there is J84A cast onto it and 4 10 6 stamped into it above the ID plate.
On the rear of comp housing you have 4 numbers: 5327-5794, 5617, K27.015 and HJ.
The exhaust housing measures 60 mm on the outlet side, inlet ports times 2(split pulse) are 45mm by 29mm each.
On the outside of the casting the scroll is 75mm where it leaves the T3 flange and about 40 mm where it meets the wheel trim
For Sale due to upgrade
$950
WILL ACCEPT COD IF REQUIRED
https://www.sau.com.au/forums/topic/84170-t04e-turbo/
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
