Hi guys,
can anyone tell me the offset that would fit flush with the 33 guards
front 18x8.5
rear 18x9.5
been reading this topic but just cant find it, always slightly in or out
+30
Hi, I need some advice on fitment.
Would it take a lot of work to fit something like F: 18x9.5 + 30 R:18x10 +30 to a 33 GTST?
Have Tein superstreets fitted.
Thanks for any help/advice you can give
will require guards rolled and slightly flared if the car is low. front liners will have to be removed.
the fronts will sit out 5mm less than this: (bearing in mind that i pulled the guards to exactly where i wanted them)
the rears will sit out 1mm more than this: (bearing in mind that i pulled the guards to exactly where i wanted them)
yes should be fairly ok, front might be slightly mexican but a good roll should fix that. back will be fairly easy with a roll only needed and maybe a 235 or 245 tyre depending how low your car is.
all gonna come down to car height on this one... i run fairly low, (320mm rear and 325) front so flaring was req'd with 235's and this is pretty much exactly the same
im sorry i dont follow 320mm what? off the ground?
30three- dont forget camber..
i've gone the less width way and more offset for the set i'm getting for my 33
they are 17x8 +5 on front and 17x9 +11 on rears.
currently they have 205/45r17s on front and 225/45r17 on rears. will see how they sit on stock guards with slightly lowered suspension but i'm thinking 215's atleast for front.
will update with picture i nthe next week ro so.
should be fine, maybe a little conservative if your going for flush look i think a few people are running 10" +22 but im not up with r34 fitment.
Think he means centre of wheel to guard. forgive my n00bness i dont know what that means still haha..
Hi guys,
I'm looking at some Tri spoke rims for my r33 gts-t. They're being sold without tyres. Basically, these are the specs:
17x9 20+ fronts
17x9 35+ rears
I know little about offset etc, but will these wheels suit my 33? Please bear in mind that the car is lowered slightly, but I do with to go lower down the track with coilovers etc.
well u'd want the higher offset rims on the fronts if anything and +35 9" wheels might scrubs on the inside if your low so test fit them first. 17x9 +20 should fit on the rears fine if you run a thin 235 or a 225 tyre.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
