Just looking for people's opinion's on the latest microtech, whether you use it or not? I know the old ones didn't use a closed loop so they were pretty bad on fuel and were bad on cold starts but i'm told by my mate that the new L series of microtech's now use a closed loop and are much more programmable etc.
He can get me the LTx12 and it will be going on my Rb20 then onto my Rb30DET. The main reason he wants me to get it is because he is mates with the South Australian distributor and can get me it at a very good price!
I have been looking at the power fc but if they really have improved i think i will get one because he can get it cheaper than a power fc!
https://www.sau.com.au/forums/topic/84261-opinions-on-latest-microtechs/
If you have a Nissan then definetly spend the extra money on a Power FC. Apart from Autronic (without breaking the bank) they are the greatest ECU for a Nissan, Microtech have made slight improvements but not enoguh to better the Power FC.
:angry:
definatel microtech most of the top cars use them
im definately happy with mine
i have also supplied and fitted 7 microtechs with no problems
mmmmmmmmm 2 very opposing opinions, this is going to make my decision very hard. so is your fuel economy pretty good compared to the standard ecu? and how are cold starts etc? if you can tell me any things that make the microtech more appealing over the power fc please tell me!
On an oooold microtech of mine the cold start was perfect. This is the hardest part of tuning an aftermarket ECU as you only get one shot at it every day and it could get costly. The advantage of the PFC is that it retains the same factory settings for cold start etc and that makes tuning alot easier.
It's been said a number of times, but I'll reiterate: an ECU is only as good as it's tuner.
You know the best way to chose an ECU?
Find a tuner that you trust, and ask them. If you find a tuner and go, tune this, and they have never used it before, they will obviously give it a go, but it probably wont be as good. And you have to trust the tuner, its a bit like a doctor, you wouldnt go back if he gave you panadol and a slap on the back if you broke your hip in 3 places.
Thats what I think anyway. Also it seems most people are using the PFC as its a plug and play pretty much, from memory wolf, haltech, etc all do plug in's now too.
I have the LT12 in my R33 and wouldnt go back. The reason I chose this one is my tuner reccommended it and knows them really well. I get 9-10km per litre but the cold start was a little bit hard to get right at first, but an air temp sensor sorted that, now its good. Its much of a muchness find a good tuner and ask what he wants to tune.
ye its a 32 so the cheapest i've found it $1380 and the microtech i can get is $1000 and both come with a hand controller. i think i will go the power fc becuse the tuner i want to use prefers power fc's!
I have a lt12s microtech in my R33 gtst and i am extremely happy with mine.......they actually cost more than the power fc's and make more power....
The power fc's still use the afm where as the lt12s dont use one at all...it is replaced with a bit of fabricated piping, so is less restrictive.
It also has more tuneability than a power fc.
I gained 50rwkw from installing the microtech but knowing a good tuner that knows microtechs helps. My car had 160 rwkw and after installing the microtech i got 209.1rwkw at 12psi with the stock turbo!!!
I have no problems with coldstarts as i had an air sensor installed at the same time.
I know a guy that installed a power fc in his R33 gtst and has got a high flowed turbo and only has 211 rwkw at 15psi and before he had about 180rwkw...... a gain of only 31rwkw.
The extra money for the microtech is definatly worth it..
Edited by lismo
Hahahaha....
That is one of the more stupid things I've heard. I'm not sure if you are serious or are an aspiring stand-up comic genius!
You'd be good at the latter.
Mate, ECU's do NOT make power. The tuning of an ECU does that. If you have say, 2 x 200HP cars. Both identical. If you install a Microtech to one and a P-FC to the other, neither will make more power than each other. I'm sure good P-FC tuners will be able to tune an ECU to make the same power as a similiar car with a Microtech. Also, you may of had such a large gain, but the person you stated that only had the 31rwkw gain with the P-FC probably got much better economy and ran a safer tune.
I would go the P-FC, simply because most tuners are more familiar with them when it comes to Nissan performance cars. Another advantage of the P-FC is the knock sensor, could come in handy one day, y'know...
Anyway, I hope you make a good choice, no matter what ECU you choose. Good luck
To NISMO
Im glad you find it so funny!!!
My car is absoulutly fine, never had problem with it and i dont find it any less economical than before the install of the microtech.....and yes it obviously produces more power as i found a very good microtech tuner.....
Its just my opinion as every one is entilted to one...and i do think that microtechs are definatly better than a pfc...
To RB MAN
If your in Brissy i know of a good microtech tuner and he isnt as expensive as most tuners.....pm me for details if your interested..
Another vote for going with the tuners choice.
My tuner (P.I.T.S) said PowerFC or Wolf3d. I tried the Wolf and am extrememly happy as the tune is perfect. Everyone who's been in my car has commented on how well it runs for a moderately modded Skyline. Since the tune and running 16psi I have never heard it backfire at all or splutter even once at high revs. This however, is due to a good tune, not a good chip. I'm sure I would have had the same results with a PowerFC.
It's all about the tune!
I hear what you are saying, but its not really true....is it??
The quality of the ignition and injector drivers surely make a difference. My old Microtech wasnt too strong in the ignition driver dept, as the thing would go up and down dependent on the load on the electrical system etc, headlights. wipers etc Also the processor speed with repsect to injectors etc surely makes a difference.
In the wash up it may not be a lot of difference, but i would be surprised if you put two ECUs on the same modded car, that they both would be able to handle the same amount ignition and boost and power wihtout having to wind fuel in and ignition out. Also certain ECUs can surely be tuned closer to the brink of detonation as they have finer control and control loops/channels etc
... I think. i repeat, think...im not saying you are wrong....but thats a few things i considered when looking at ECUs
I got the same gains as you with an safc11 so have alot of other people, should we be claiming the safc is the superior managment??
Edited by otto
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
