I have managed to find someone that will sell me some new RDA front/rear slotted rotors for a very good price for the gts-t. They are similiar od and thickness to the DBA equivalent rotors.
Who has used the RDA's and how do they compare to the DBA's??
I plan to use the RDA's for track days with the stock 4 piston r33 gts-t callipers and racebrakes compound pads till i get more $$ for some brembos or ap racing callipers.
https://www.sau.com.au/forums/topic/84358-rda-rotors/
Do a search :D:D:D:D
It is a bit hard at the moment but there was a really good thread on these exact things about a year ago. Try searching rotor threads that Roy has posted in.
I seem to recall the general consensus was that they were good value and did the job.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1526885
i have used them before and didn't have any problems but i know of plenty of people who have had problems with them. They are by no means a 'performance' rotor. they are just a cheap arse made in china disk.
all depends on how cheap is cheap and how much importantce you place on your brakes.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1526895
Rotors & Drums commenced operations in Melbourne Victoria in 1987 and has grown from a small trade and retail parts supplier to today offering the largest range of Disc Brake Rotors and Brake Drums in Australia and New Zealand.
Our range encompasses some 1530 vehicle applications and covers everything from Alfa to Volvo and all makes in between.
We also stock a large range of applications that were not directly released into the Australian and New Zealand market, but have found their way onto our roads by way of private import.
Rotors & Drums is Australia’s largest Independent Rotor and Drum wholesaler and is a family owned company.
U sure they are made in China????
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1526903
Denham I hand you your ass at the track using them....and a few guys using the rediculously priced DBA stuff.
Go with them mate. Never heard of a failure and yet the DBA stuff is a bit of a concern in some circles and I do know of failures and a well known race brake expert dislikes them.
DBA sponsor Improved Production in NSW. RDA sponsor same in Vic.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1526986
Ive been using the RDA stuff for a while and like them.I havent used them for circuit racing but use them for drag racing in one of my cars which uses green stuff pads and they work well cold braking at 140mph. I had a bit of a bad run a few years ago with dba rotors where they would start to shuder and stuf after a 1000k's of hard driving and whenever i rang and asked for a reason why it was happening i was allways told it was because of brake pads or not being bed in properly. So i tried some cheap rda rotors and never had the same problems again.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1527470
Jeff u think the gtr size 325mm od fronts of the rda can be used with an adaptor to fot on the gts-t like the dba gtr ones can?
The GTR ones are not much more but are alot bigger.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1528126
Denham, consider the thickness as well. Are they 33mm compared to the 30mm of the GTSt size?
If they will fit then do it. Get the spacers made and enjoy. Might be some extra cost in the final solid brake line elbow mod though.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1528289
I know brisby is using some 5000 dba's with adapter and apparently working well for him. Is racebrakes the only place that sells the adapter?
So ur using the rda gts-t replacement front rotors right? How many track days have they seen and what condition are they currently in? I can get them for $150 each front and $75 each rear.
whats the final solid brake line elbow mod required?
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1528304
Mine are not DBA 5000s, they are only the 4000s. Race Brakes no longer do the adaptors, it seems that RB - Vic isnt a fan of them , so stopped doing them based on the fact that they feel it is to much a compromise.
Be careful when grabbing too thick a rotor, you may find you are needign to machine down the pads so you can get them to fit, as the calipers may only be designed for 28/30mm etc rotors
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1528403
Both the 4000 and 5000 fronts are 30mm thick.
I am talking front rotors here not back.
How else do you fit bigger than 296mm front rotors on a gts-t?
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1528420
MILD TRACK USE WITH EBC GREENSON
THE MAZDA,
A MATE OF MINE USES THEM ON HIS E30 RACE CAR WITH
EBC PADS AND THEY LAST ABOUT 70-100 HARD LAPS
DEPENDING ON WHAT TRACK,
FOR A WEAR AND TEAR ITEM THEY ARE PRETTY GOOD
VALUE FOR MONEY
do they need the alloy hats to fit or are they direct fit?
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1528780
Denham
No they are not alloy hats, especially not at that price.
The thickness of a GTR disc is greater (33mm) than the GTSt so I'd be concerned if they are selling that size in a narrow disc of 30mm. Maybe just an option for GTSt but not for GTR.
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1529133
Denham
The dba 4000's for the gtr are also 30mm thick.
I can get the rda's for cheaper than that site i posted the link to :P
Are these the fronts ur running geoff?
http://www.brakesonline.com.au/catalog/pro...roducts_id=1731
https://www.sau.com.au/forums/topic/84358-rda-rotors/#findComment-1529153
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
