Garret Gt3xx Confusion
PRO_32
 Share
Maybe someone here knows?
I've been told that the garret GT30 range is essentially the same
ie GT 30
GT 30 37
GT 30 71
GT 30 40
the last three i can find info on but not the gt30 or is that a generic term given when talking bout any of those three.
cheers
Andrew
its a GT30, they different people slap thier own numbers on the end like
40
5002
12308142357962385
it really doesnt matter. what does is the wheel trim and the compressor map, not the little numbers they all slap on the end of them
Sorry for the slightly off topic post.
For those that have GT30's, did you use a hi or low mount manifold? I know both have been done, but is there any benefit to either the low or high mount manifold set ups?
Also, I've pretty much decided on going with the GT30/40R on my RB25. I currently have the following mods (either on the car or ready to go on the car): PFC, FMIC, EBC, 555cc injectors, bosch 040 fuel pump, Z32 AFM, Adj Ex Cam gear, 3" exhaust with hi/flow cat (i'll be getting a new dump pipe made up). I'll also be getting a Tial 38mm wastegate once the turbo goes on. Is there anything else I'd need to run say approx 270rwkw?
Thanks guys - and apologies again for the off topic post :P
Variations in the GT30R series . Basically there are two turbine variations , The first is the std GT30 turbine , the second is the cropped compromise .
Compressors come from two families , the BCI-18 series which are the propper GT series and CAD (computer aided design) developed with more modern fluid dynamics technology . The second are the old dinosaur T04S types developed in the middle 70's .
Cost difference is due to late designs costing money to develop and like anything that gives superior performance - you pay a premium . Garrett is a business after all . If you want superior results you have to pay for them , same with oil tyres etc
Part no's , these are to note the many variations available for Garrett and everybody else .
Don't let the sharks tell you they're all the same because they're not , they have different characteristics to suit different applications . Do some research .
Cheers A .
So what do you look for in the model coding to determine whether the compressor assembly is the "true" GT series?
As a bit of an aside, I have seen a GT32 listed, which is a plain bearing, internally gated job with the T3 flange, matched to a reasonable spec 71mm compressor assembly. With a 64mm turbine, is this a viable alternative to the GT30 models for Skyline?
cheers
That turbo (GT32) is a problem , it has a twin entry or "split pulsed" exhaust housing and the integral gate looks to only vent one of the two entry passages .
As I said the real GT30R (with the 6 full and splitter blades BCI-18 family GT37 compressor) goes under turbo number 700382-12 or -11 for the 56 trim compressor . The cartridge or CHRA no is 700177-0007 . For the 52 trim version (I have only ever seen this on HKS optioned GT3037's) the turbo number is 700382-9 or -10 . The cartridge or CHRA number is 700177-0006 .
Easy rule of thumb is normally 76.2mm GT37 series compressors come in T04E type compressor covers whereas the dinosaur 7 bladed (full and spliter) TS04 wheels usually live in .70 ARR TS04 covers which normally have 2.5" outlet and 4" inlet .
The stand out is the Ford BA XR6's GT3540R which has an 82mm GT40 compressor in a .50 ARR T04E cover , the integral gate and FORD cast into the exhaust housing identify's that one if its not been altered by sticky fingers !
Cheers A .
 Share
    • They didn't. This is their comments; I'm not sure why they don't have the OEM specs.
    • Did the oil analysis include the acceptable range for Lead? Last one i has said 1ppm is the limit and the engine I was testing had 74, 80 and 33 (was the race car, tested from brand new run in engine). It may not help to tell you the engine didn't last long, but they never did back then
    • My engine has only an oil pressure switch from factory and I've installed an after market sensor that will alert me to pressure loss (https://www.sau.com.au/forums/topic/484431-my-bmw-335i/page/3/) . These engines can definitely feel long left/right handers which is why I added this sensor. There are no other symptoms at all. No strange noises (in fact after the turbos were replaced the mechanic made a note of how sweet the engine was running), no smoke, no glitter in the filter, nada. I'm just a stress head with car issues, I hate there being anything at all wrong with my cars, even if its basic. I just immediately get anxious and start thinking about catastrophic failure.
    • Do you know where the EPS module will be located? And also the diagnostic connect located under the dash?
    • Well, yeah, there is a (very thin) layer of soft lead on the surface of bearing shells to provide that first "cushion" against physical contact. Just because it is wearing off doesn't actually mean that the engine is dying. Of course, it can mean that the engine is dying. If the engine is making no noises and the oil pressure is (mostly, as in most of the time) fine, then it could just be suffering under particular conditions. That could be startup, or maybe at some point in the normal operation cycle - or maybe the Beemer engine suffers under long left hand bend (see, highway on ramp) and the pressure drops. You'd need to try to work out if any such thing is happening and then determine if you need a bigger oil pump, or an Accusump or something.
