Hey guys desperatly seeking the front and rear bars and would like to inspect before buying.
And no im not getting them from Jetspeed. <_<
Also does any1 know if the front bar(made for series 2) will fit up2 a series one R33?
Cheers
Cheers
damn that kit looks hot. not too over the top, just how i like it! looks factory
Jar, I noticed you post the exact same reply in his other thread. Just let him do what he wants, it too doesnt make sense to me but isnt my car. Seems as though he wants an aftermarket/modified series 2 to fit on his car. Personally, I wouldnt buy that kit as a it being aftermarket its easily going to cost xxxx amount while a stock series 2 bar would be considerably cheaper.
it isnt factory.
also.... why do you want a series 2 bar put on a series one :S, it still makes no sense to me why you would swap a stock bar for a stock bar, see my pic <<< stock bar
i know its not factory...
when someone says something like that "it looks factory" when referring to an aftermarket mod, it means it suits perfectly, and looks like it could've come that way out of the showroom :P
yeah i know, im not saying he shouldnt, i jst dont see what sense it makes is all :D
btw, thats a nice pic in ur sig. :)
when someone says something like that "it looks factory" when referring to an aftermarket mod,  it means it suits perfectly, and looks like it could've come that way out of the showroom :D
:lol: ohhhhhhhhhhhhhhhhhh i get it, **JaR** and 2 hours of sleep last night and red bulls this mornin equals.... :)
Reading comprehension is strong in this one.
A front bar made for series 2, such as the one in the photo.
He didnt say a stock series 2 front bar
Have a look guys its not stock, plus i dont have series 2 indicators so without that the gap will be bigger, plus, its only being used as a base, hopefully u can see how 'stock' it is at MAS.
so anyone know where i can find this? Im pretty sure theres at least 2 peeps from Vic that can supply this kit, if u are please own up..
Oh and can S2 bumpers fit S1?
from what i've read...not without chaning to series 2 headlights, and bonnet.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
