How long is your breaker bar? failing to budge it try and use an oxy to heat it up, weve done it many times at work to patrols/navaras and the like, by the way i hope you checked you could get the filler plug open first :(
the bar is abou 400mm long and i couldnt move it so i attached a 3ft pipe to the end and thats when the plug warped a lil.
might try the oxy, been a while since ive used one....
the filler plug wont budge either, but i didnt have a decent crack at it, worse comes worse it can be filled from the gear stick im pressuming.
going to put the car on a hoist next week and give it another go.
any other ideas?
don't use a rattle gun. The stupid servo that I took it to (before I learnt anything about cars) used a rattle gun. the thing is, the head on the gun isn't a perfect sqaure like on the breaker bar. it's a f**ked up smaller rounded shape. They ruined my plug a bit.
those plugs are always a killer to undo. I managed to get mine done without too much cursing or blood on the floor with stand and jack.
when you say you wrecked the plug a bit, that's fine. the plug's dirty, most likely you just scraped a tiny bitta metal off and it looked clean. give it a decent crack on the hoist if you can't on the ground, and next time, don't do it up so tight.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
