OK just some update on the progress of emanage ultimate...
Got a call from Trent at Mercury Motorsport over the weekend, He say they finally got the car started with the unit installed, now they just need to do the tuning and hopefully they won't be too much drama in that department.
Trent told me it was pretty much the 1st emanage ultimate installation in QLD, not sure if he meant on GTT or all car, as they were trying to compare notes with other technicians.
Praying it will finally be done today of tomorrow. Oh btw, the Blitz SBC i-color is done.
What's with this thread???????????
I asked jas/slo32
Was that an AFM or MAP sensor driven Supra?
And I get no answer.
MacGuyver asked rd-runr
That's pretty good, was it on an auto or manual? If it was an auto, was it with the injector harness only? What other mods did you have at the time?
And he gets no answer.
I ask rd-runr
Is that fuel tuning only? Or ignition tuning as well?
And I get no answer
hoo@h has his car at Mercury Motorsport on the 26th August and they still have it. Now the guys at Mercury ain't inexperienced with Skylines and they couldn't get the EManage to work in 10 days of trying. For a product as expensive as EManage that seems a little excessive to me.
I don't think I will ever seriously look at an EManage as a solution for tuning on any of my cars.
:) cheers :(
:P cheers  :)
well, they gave me a quato of one or two days to get it fitted and tune, but endup been almost two weeks now.
I guess because the Emanage ultimate now have all these new stuffs to work with auto, the wiring of fuel+ignition+ auto assist got complicated or something. I don't know, not a tech head myself.
Anyway, will have to see if the result is any better than say a blue Emanage.
Don't get your knickers in a knot princess, not everyone lives on the internet and tediously checks every thread they post in daily. :P
I have a shit load of mods sitting in my house still, need to get em all installed, should be a painfully expensive process.
so are you saying the installation manual is incorrect for the skyline(s)?
surely MM can follow wiring instructions?
Well, I actually print out the whole english manual for them, I guess either the wirediagram is bit hard to follow or they never read it. I don't know.
At least everything is hooked up now and the car starts, will Have to see what else can go wrong and hopefully getting my car back before this weekend.
Hey Nox, are you in Brisbane as well? Have you decided on which place to go to get your ultimate install? I guess MM will be the best place to go once they get my lab rat sorted. Coz by then, they will know how to wire up and what will go wrong.
I suppose it's too early to tell but has anyone heard of any problems with regards to Emanage Ultimates? I'm about to get an Emanage Blue back from Trust Japan after I returned it on warranty, apparantely the unit "wouldn't communicate with the stock ECU". Just wondering about my options incase the Emanage is a lost cause for me when it comes back (if it still doesn't work). Does anyone know if the injector harness for an Emanage Blue will work with an Emanage Ultimate (I still have the "Blue" harness installed in my car!) or maybe I should just get an SAFC II and cut my losses.
"Oh no it's the cops!"
"Worse, the police cops!"
Oh well...let us know how it performs.
The latest news from MM this morning, sad but true.
The final decision has been made, the guys at MM had tried their best and had contacted all the people they known but still can't get it to work.
Basically, when they connect up the whole unit to the ECU, the car runs rich at start and as the car warm up it start to run thin and then the engine will cut out, plus the auto assist goes funny, when they put the car into drive, it always start in 3rd gear not 1st. And please don’t comment on the technical ability of MM, unless you have successfully done the installation and tuning of the “Emanage Ultimate” on a R34 GTT automatic.
So unfortunately, we are calling it a quit today, there's no point of dragging it on without any more information. So on till there's more info available for the ultimate unit n GTT auto setup, then I shall bring my car back to the workshop.
Please let me know if anyone else has the unit and had it working with R34 GTT automatic in the future.
Good luck Nox, hope you can get yours to work, and please inform us if you do get yours working.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
