  • Replies 56
I don't think mr nissan would go to the trouble of including these rails just for cosmetic purposes as they are under the car where only your mechanic will see them :blink: ... sure they might not be true chassis rails like on ye olde cars, but they still are a structural part of the monocoque chassis and they look to add a lot of strength to the floor. I think the vehicle examination people are quite right to expect it to be in good condition and its a bit of a worry that chassis specialists dismiss a big dent like that so lightly. The other thing you need to make sure is that it hasn't twisted or bent the rest of the chassis.
its a 99% probablility the rail is spot welded and to remove it the easist thing to do is buy a special spot weld removing drill bit and drill them out. you are then left with a hole one side (in this case in the floor pan) that you can plug weld from inside the car to attach the new rail. The bigger problem i think you will have is getting access to the rail where it looks to sit inside another rail section and no doubt there will be access problems elsewhere. Unpicking spot welds is time consuming and fiddly work.
like someone else said 2k sounds about right to do the job properly....
Nice find with the chassis rails.
This is most definitely what I will be doing.
Have I attached a pic of the underside of a VL Commodore?
Its not suprising those things pop windscreens, lol. :blink:
http://www.skylinesaustralia.com/forums/in...pe=post&id=2157
Edited by Cubes
ok, i just talked to a guy that works with my wife, he used to be an automotive engineer and has some contacts that can weldup the new rails.
Im going to buy 3 rails from nissan, The crushed one and the 2 on either side of it.
I was picking at the rail yesterday and found it was roughly spot welded every 5 to 6 centermeters.
Ill remove the old rails, and get this guy to weld up the new ones.
Im waiting for him to get back to me.
Steve
here is a pic from the fast software
it show the bit thats crushed, and the 2 other bits that are damaged.
The one thats slightly damaged, il replace anyway cause that the bit that the gear box member bolts onto.
the smaller rail ill also change just to make it all look better.
ill keep you's updated.
steve
Edited by PHATR32
grafting in new rails is definately the way to go. you really need to make sure everything is perfectly sqaure though. I cannot stress this point enough.
best of luck, i will be interested to see how it goes, take plenty of pics.
ill keep yous posted, i just talked to the engineer guy and he said he'll be seeing his mate tonight. Hopefully this guy will be able to sort it and let me take pics too!
I assume getting the whole bar mig welded would be better than spot welding it??
i hope it turns out to be ok.
Steve
i just talked to nissan, the crushed bit is $141, the slightly damaged bit is $101.60 and the little one doesnt exist any more cause they dont make them!!!
so i guess i wont be changing the little one, which mean ill have to be carefull when removing it.
steve
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
