Item:12/1998 Nissan Stagea Series II RSFour 4WD Turbo
Item Condition: As new condition. Only 43,000k's with no marks to interior or exterior.
Reason for Selling: Buying a house, so ditching turbos for a while.
Price and Payment Conditions: $24,000
Extra Info:
With only 44,000 kms, immaculate presentation, equipped with two sunroofs, dual airbags, the power of the R34 GTT Skyline engine, the safety features of the GTR Skyline ATTESA all wheel drive system, tiptronic-auto transmission, factory 16" Nissan R33 GTR Skyline look-alike wheels all combined with the luxury and comfort of this elegant Nissan, this car boasts practicality with power and style...
Perfect as a family car or a subtle, yet seriously powerful machine. This car holds extreme potential for modification with the powerful base engine being the RB25DET NEO from the R34 GTT Skyline, but does not scream 'look at me'. This Series II Stagea has a dyno proven 120Kw at all four wheels, 100% standard..
The car has an updated audio system consisting of a Pioneer headunit and Blaupunkt speakers. There is an option of two 10inch Blaupunkt subs and an Epsilon amp for $800 extra. This car also comes with a top of the range paging alarm system and 3 point immobiliser.
Owned by a female who is pedantic about the car and services it every 4000km using Motul oil, it is in its very best possible condition both mechanically and visually. Only reason for selling this beautiful car is that I am buying a house and cannot keep this stunner as well. Very, very regretful sale and the new owner will not be disappointed.
Contact Details: Want more pics or info let me know. Call Samantha on 0433 268 075 or 5594 4435
Edited by FYN33
https://www.sau.com.au/forums/topic/85116-98-series-2-nissan-stagea-rsfour/
Hello,
How are you doing today?and work? hope fine.I saw your car for sale . My client is very interested in this car .please get back to me asap, i have go through the details and the pics of the car, sound great to my client.Get back to me with the more details and the condition of the car.so that i can instruct my client to arrange for the payment.Can you accept wire transfer?because that is my client method of payment.Am buying this onbehalf of my client.I base in london.As a matter of urgency.
please get back to me right away. Thanks and have a wonderful weekend
Regards
Bright Markus
Tel:+447031848524
Fax:+448701363171
[email protected]
Hello,
Regards
Bright Markus
Tel:+447031848524
Fax:+448701363171
[email protected]
Sounds like the oldest scam out there. Dont listen to this...
Judging by his other 4 posts in random for sale ads, i agree krzysiu.
dont really get how its a scam, but i dont believe he is serious.
still for sale.
cheers :)
dont forget the $500 spotters fee. . tell everyone you know and if they buy, you get $500 cash.
Edited by FYN33
price drop, 24k ono
PPL's - this is a top price for such a sweet vehicle. Who wouldnt want a 'R34 wagon'?
Flyn33, I bought my series 1 Stagea a few months ago (flew up to qld to see the car & do the deal, and had the car trucked back to sa) - I really wanted to buy a series 2 but didnt have the 28k necessary to grab one from qld.
Good luck with the (unfortunate) sale!
BW
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
