  • 3 months later...
i had screws holding the square surround at the bottom, so i found that the only way to get the square surround off was to take out the cluster (gauges, aircon, radio) via the two screws at the top, and two at the bottom.
  • 3 weeks later...
finally did mine... The wire descriptions Alex has put up in the first post are the same in My S2 fours S, so it saved me a lot of time!
On the rear speakers, 1) the speaker covers don't seem to come off 2) there doesn't appear to be any screws on the whole door panel (as mentioned earlier in this post). Ideas anyone??
Ian
tRUkbOY - there is no standard amplifier
Ian - To do the speakers, you need to remove the door skins. From memory, the only screws holding the rear skin on are under the top part of the hand holder part.
Start from the bottom of the skin and unclip it from the metal door. Finger strength will be more than enough. Move along until all the clips are undone, then lift it UP off the frame. Be sure to unplug the window switch and away you go.
The rear speakers are screwed into the spacers they use, so you will be able to basically directly replace the speakers.
The front speakers are moulded into the plastic spacer. I used two 16mm spacers glued/screwed together as spacers for my speakers.
The paper is just there to give a better seal between the two layers of MDF. The heads of the screws holding both plates together are in between all the screws for the speaker and the heads are sunk into the wood.
i got all my speakers in using the stock holders
Yep me too, a little tight, but they fit, i also had to trim a little out of the back of the spacers aswell, to fit the larger magnets in.
Firstly, my speakers the magnets easily didnt fit in the stock areas, i had to cut the back out of both the front and rear spacers.
2nd, due to the fronts being moulded into the plastic, after cutting out the stock speaker with a dremel, i found my speakers were just a little over sized (I could get 2 of the four screws in, not all 4.)
I tried so hard to use the stock holders, but they just wouldnt hold. Also, the front plastic seemed pretty brittle, but hey.
So, i had to use massive spacers to fit my speakers in without hitting the door. The stock spacers are ~36mm front and 32mm rear.
I used to fit car stereo's for a living, and personally i think wood or MDF is a better sound producing material than plastic anyway.
As Alex can probably confirm, it's quite easy to make MDF spacers, they dont have to look spectacular, as it's all hidden.
Yes, the rear antenna has a power wire.
Its the yellow/black stripped wire that is taped to the antenna wire.
Attach this to the power wire.
Mine has no wire attached to the antenna wire
The only yellow/black wire I can see is very thick and wanders off the direction of the steering wheel.
The best choice I have left is to trace the wire back from the amplifier (that's the antenna signal amplifier).
The question is where is the antenna signal amplifier?
:D Cheers :nyaanyaa:
You are quite lucky that i have a big hole in my dash.
Here is a photo of the power antenna wire. As i said, the wire for it is taped to the antenna wire (which in my case bends downwards). The two wires are then covered in some foam stuff and go up and to the left...or the right, i cant really tell.
That black/yellow wire is what you attach to the antenna.
If that wire is not attached (like mine), you will get terrible reception (in dips in the road/under bridges etc, reception will cut out. When you do attach it, it really REALLY makes listening to the radio a lot better.
I am just lazy to fix it for now.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
