ok now ive just read through this whole thread and im still lost, ive got a factory tape deck/stacker setup, ive got the plug with the 4 wires that someone said was for satnav plugged into my headunit, so ive got 3 plugs in the head unit and one empty socket, i also have a round socket 5 or 7 pin i think, with nothing plugged in to it. there was also a frequency expander in there that the plug broke off when i was poking around. and there is an extra plug in there going no where. can anyone shed some light on this??
Take some photos and post them up, it will make things easier to identify and get help! :P
The round plug is an 8 pin Din plug, that connects the Xanavi to the HU. Supplies the audio from Xanavi, Combo power on trigger, Aux on trigger and the Aux request wire.
The Left hand lower plug is the constant power, ignition on, and the LH/RH speaker wire. I can't remember whether it's front or rear. The right hand plug with 4 wires is the LH/RH speaker wires. Again, I'm not sure whether it's front or rear. The top left plug is the plug that goes off to the stacker. Do you have a patch lead between the main chassis loom and the bottom left plug? You may find that you do and it'll have 2 wires a yellow and red. The is the constant and ignition wire for the stacker.
yer that would all make sense, now i just need to work out why my climate control light on one end has gone out. there is also 2 diffrent plugs in behind my headunit that are just sitting there on the loom goin no where, one looks like it might be for the ok meter type guages that replace the clock but thats just a guess. does anyone know if the stacker will work with newer clarion head units? i just dont want to take it out and have nothing in the whole.
  • 3 months later...
i'm in the midst of installing my dvd/tv double din stereo
reception is rather poor although i hooked up the amp wire to the black with yellow
well actually i spliced it into the loom and left the plug connected.
the old FM converter was spliced into the nearby constant acc power for the ciggy lighter, so after reading THE WHOLE THEAD and not just the first 4 pages i'm going to separate the loom and try running 12v acc to the black with yellow.
the unit i have has digital tv and i have put the arial into the roof above the hoodlining - but i can only get abc 1 2 3 and 24 and with a rather weak signal. i'm a little reluctant to mount it on the outside of the car as the cable is not very long and therefore i cant put it near the back wing like i had hoped.
where has everyone else hooked their arials for DVB???
i'll post an image if the unit in the day light tomorrow - but while i have it out i'll finally wire the boost guage i have up to power as its been 3 months with no guage at night lol!
wires as stated in first post were same for series 2 and never double checked them, just spliced them into a new loon and plugged it in (put the old one in later if i wish)
thanks heaps for this DIY!
  • 5 months later...
Sorry to bring up an old thread, but i just ripped out my head unit to reroute the ipod cable, and moved the cable and now its not working. tested the connections with a multi meter, and i have Constant but cant get 12v+ to the stereo? Any help would be great.
You mean you have no 12V at the supply to the stereo? Have you checked the fuse in the fuse box? Also check the inline fuse in the wiring behind the stereo. You might have shorted something and blown the fuse.
I have replaced the fuse in the fusebox as that was blown, where abouts is the inline fuse? How far in behind the stereo?
i think he's talking about in line of the power wire coming from your hu
it may or may not have a fuse there also
or perhaps there's a fuse directly in the hu?
So is there any other fuse or anything i could have tripped other than the audio fuse in the engine bay? Becuase i get 12V+ at the fuse , i also get 12v constant from the brown plug i just cant get acc to turn on.
Edited by 4door31
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
