Hi,
It's been ages since I have posted on the forum... I need some advise to get my car back on the road. Please excuse if I get the jargon incorrect, I will try to be as accurate as possible.
A while back (cough.. 4 months) I munched piston #6 :D
After investigation (first time head has come off) all pistons are @ 86.5mm - cylinder #6 has a score to 86.7mm. (more on the thrust side if that makes a difference)
Now, I have been told that it may not be good idea to bore to 87mm on the RB26??? Also been told that sleeving can disrupt or distort cylinder #5 - can someone please give me advise on this and if it is possible. My other option is to get a new or second hand block? Is this worth while or can my engine be saved as is? Arias have a pistons up to 87mm
Thanks in advance.
Robin
FWIW, I'm pretty sure 87mm is a "standard" 1mm overbore, which is within factory tolerance (Nissan will gladly sell you 87mm pistons to suit a RB26DETT). There should be no problem boring to accommodate 87mm pistons.
87mm is fine..but are you sure the nores are already 86.5mm? Did you measure them?
Thank you for your help.
I have had the pistons measured @ 86.5 (aftermarket) and nores to 86.7mm or there abouts - the motor had larger pistons placed in prior to me getting the car from Japan (I'm still to find out what else has been done to it, it will be stipped down over the next week or so)
Fair enough, the only reason I asked is that I have seen 86mm RB26 pistons that have '05' on the top (as well as the 05U). The '05' was some sort of casting ID mark.
The 86.5mm nissan pistons have '50' at the fron where the piston grade ID normally is.
I have a spare set of 87mm GTR pistons sitting in the garage, good as new if anyone is interested..
How much? Are they new? Brand?
I was thinking of getting the Arias for $1070 + GST
Get ylwgtr2 to Knife edge your crank!!
*drools*
Peter, long time no type / speak.
I remember at the last club meeting I attended I had a good chat to ylwgtr2 about the problems I was having after PI - he hit the nail on the head and said DONT DRIVE IT, get it checked out ASAP - what did I do... take it on a drive to Lakes Entrance that weekend and the rest is history.
After he slaps me around the head a few times... How much you reckon he will charge to knife edge my crank shaft? Is it balanced and polished after also?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
