saw a white r33 in an accident lastnight around 11 oclock on dandenong rd. infront of that pool place i think its called prince. the road looked kinda blocked off. cop lights flashing and stuff. anyone know wat happened. i felt sad as i drove past cos my car is also a white r33. also every one okay ? i think it might hav been some youngsters from the pool joint.
https://www.sau.com.au/forums/topic/85830-r33-crash/
i drove past it last nite too. skyline had damage front right and looked like it spun around. the other shitbox(literally a shit box) had damage front left i think so i assume the shitbox was chucking a right into the service rd and smacked into it or the skyline was comming out of the service rd and smacked the shitbox. could be anyones fault.
https://www.sau.com.au/forums/topic/85830-r33-crash/#findComment-1552948
Sorry was a good mate of mines mint SII gts-t (from monash nissan club). He got clobbered pulling out of the princes, was really really sad. .The car was a write off. I despise those of you who instantly assumed it was his fault. Thankfully he's on full comp insurance.
https://www.sau.com.au/forums/topic/85830-r33-crash/#findComment-1559166
Well...... wasn't it?
According to what you just said, he's pulled out into traffic without looking, which has resulted in his car being hit.
If it was the fault of the other driver, it wouldn't matter what sort of insurance he has, the onus would be on the other driver.
:D
https://www.sau.com.au/forums/topic/85830-r33-crash/#findComment-1560208
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
