Well I've been here for a while so I might introduce myself.
My name is Tony. I'm a refugee from the OCAU forums. I'm in Sydney and I work in IT.
I've been very busy with my car:
http://www.nitroware.net/~tony/r33_front.jpg
http://www.nitroware.net/~tony/r33_rear.jpg
It's a 1995 GTS-t 5 speed with an ARC FMIC, Apex'i AVC-R, PowerFC, HKS BOV, HKS filter, HKS timer, HKS suspension, Recaros. Sound is the JVC s985 and Alpine 6x9 + 6.5 doors. I'll probably go the full 400r kit in a while. The orange front indicators will be clear items once I get around to painting the globes orange.
And that is my story :wave:
Maybe you guys can fill in your rides.
T.
https://www.sau.com.au/forums/topic/8596-who-are-you-heres-me/
oooohhhh man.....gotta love the TE-37's....wheels of my dreams....do u mind if i ask how much u picked them up for?
Yeah benm, i reckon a SII wing looks awesome, but i don't mind the stealth wing, cos the car is so low, makes it look pretty sleek.
man, that's a sweet car.
I think it's just plain silver. The light must be funny that day, no flash, I'm a pro :D
I am server/network/SAP monkey. Let's just say that it's a VERY conservative 220kW at the flywheel. I run 0.8 bar usually and never try to jack the power full on unless the road is perfectly flat and the car is die straight.
I've had too many hairy incidents with full power on in corners...
T.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
