The Grasshopper was kit number 43 from Tamiya. A 1/10 scale off-road vehicle.
Specifications
monocoque plastic chassis
solid axle rear-wheel drive drivetrain with bevel gear differential
independent single A-arm front suspension
coil spring suspension all around
RS-380 electric motor
extra wide rear paddle tires and ribbed front tires
hard plastic ABS body shell
I've had it for about 2 years - but only ever used it about 5 times. I'ts in good nick and has all the bits & pieces, including glow plug battery, tools, nitro (better not post nitro to Darwin tho). It might need a bit of a tune etc cause it has been sitting in my closet for a year and a bit.
I think I paid about $550++ for it - I'll sell it for $200 plus postage.
https://www.sau.com.au/forums/topic/8620-wtb-petrol-rc-car/#findComment-125956
  • 4 years later...
I have a sidewinder buggy RC nitro car, brand new and sealed with everything included to run including the glow plug! Asking $200 posted anywhere with insurance. Please only call me on 0412500318 if interested as i dont go online.
Its got 18cpx 2.95 cc engine and can go up to 80kmph. It is also a 2 speed!!
It will be going up on ebay tomorrow
Edited by popeye132
https://www.sau.com.au/forums/topic/8620-wtb-petrol-rc-car/#findComment-3561722
