ok I would like to know how to remove the Air vents I tried to remove the passenger side vent and it snaped (Glooing it together as I type) I have tried to serch the fourms all I can find is parts and ppl asking for them but nobody as far as I can tell has posted up on how to remove then safely
https://www.sau.com.au/forums/topic/86452-air-vents/
oops my bad I own a R32 GTST :)
Well the screw driver trick in the manual is a crock IMHO: its almost impossible to get them out without damaging the vent blades (when trying to get some leverage with the screw driver) or snapping the tabs.
Really the only safe way I can think of is removing them by getting at the back of them (which means undoing the dash and rotating it enough to get at the vent).
Maybe others have a few tricks.
https://www.sau.com.au/forums/topic/86452-air-vents/#findComment-1563136
I also want to remove my vents one day, when i get the time for my custom-sprayed interior! ;) My 96 R33 vents appear to be quite brittle - i don't think i'd get them out without breaking them & replacing them... unless someone can offer some advice...
https://www.sau.com.au/forums/topic/86452-air-vents/#findComment-1565342
Well thats what im doing and I lernt my lesson also I think it would be good yo clean the blades as I have seen how dirty 15+ Years they are good clean air :P I was hoping they would be like the Side vents for the side windows they just puped out no probs
https://www.sau.com.au/forums/topic/86452-air-vents/#findComment-1565900
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
