YAY New Cooler Is In
  • Replies 92
Originally posted by INASNT
and how did i know u would say that, how predicitable u r ambz!
anyway, stop hijacking my thread, u bloody tamil tiger!!!
haha...like a tiger...*roooaaaar* :lol:
geezes....$600 for piping...that's more than my intercooler alone :eek: (33 GTR FMIC)
I was just thinking mild with hi-temp paint on it for myself :)
the piping came in 3 pieces so it saves time on welding and adjust etc!
If u were to buy 2.5inch pipe get it coated and then mess around with labour of getting the right angles etc it comes close if not more than 600!
pipe from turbo to intercooler intake, pipe from intercooler exit to engine bay, and pipe from that to intake!
then dont forget about all the hose clamps, silicon hoses and rubber fittings!!!
u sure franks is just gonna let u pull off that off just so u can get a copy of it??
I know if some1 asked me to pull my front bar and all clamps, hoses and piping off just to copy my piping, i would b asking what was it in for me!! :)
yup b'cos he has another car to drive for awhile and I'm making a box for my apexi cone filter, so he'll just grab a copy of that off me. :P
hmm what does the box u r making look like now! I had a partition in place when i had the stock cooler and piping and now it is usless since i have heapes more room to play with now!
I need to get a nice funnel up where the stock cooler was with sum piping into the engine bay through the stock cooler holes!!
I haven't made it yet, gonna make some templates from cardboard, then trace it onto the aluminium sheets I got at home, bring to a laser cutting place and get 'em cut out, then welded together and powercoated flat black so it (hopefully) will look stockish and the cone filter will be hidden.
EDIT: this is for a 34...would it be same fit as a 33?
Originally posted by ed
ahhh, looks like the hardwork has already been done?!?!?!
will have a closer look tonight.
i think you will find on the 34 that the radiator overflow is in the way - as it is on the same side as the airbox [LH P/S]. Whereas on the 33 the airbox is near the battery [RH D/S]
that template is if u have the stock cooler and piping, so u gotta modify it abit with fmic. in r33 the battery is in the boot so it aint in the way of the airbox! :)
