  • Replies 63
Originally posted by GTS-t VSPEC
Hicks,
I thought I was the only one who didn't like you, looks like everyone else thinks the same aswell.:bahaha:
You know you love me, paul. :shake: :whackit:
I'm headin down to the plex tonight, watch a couple more of your mid 14 passes.
hicks,
I know you came down but seeing as I only ran one 14sec pass and all the rest were 13's then it would have been a sorry night for you. 13.5 is my new PB, gives you something to aim for.
See'ya:burnout:
P.S. I love you.
Did you see the latest HPI, where they compared the R34GTR to the Commonwhore GTS, the GTR was best in all areas apart from passenger space, but in the comparison of rolling starts the GTS kept up, so it has power but nothing else.
At $100K, I know which I'd rather have, yeah thats right an R32GTR with $70K spent on mods, Fark yeah:D
See'ya:burnout:
