Does anyone have any info on the laws on window tinting?
I heard that if the car is pre 1991, then you can have them as dark as you want. But then i also heard that it has to be on before rego.
Can anyone clarify this for me at all?
I'm looking to get dark black, brown or purple tints for my HR31 GTS-x to try and keep that 80's look going as well as making it look nice.
https://www.sau.com.au/forums/topic/86733-laws-on-window-tints/
Jago, yeah it has to be on pre-rego, have a look at the link.....if it was first registered before August 1994 you can have dark tint, as long as it's already on the vehicle..
any new tint put on has to be 35% VLT (visable light transmission)
http://www.rta.nsw.gov.au/registration/dow.../vsi03_rev3.pdf
pete, reversing is so hard because of the cans you consume. i've seen your car, there is no tint mate, it's the beer goggles you can't see through... bummer.
i must agree though the dark tint can be a bit of a safety hazzard, my quarter windows and rear screen are pretty much black. it's a real bitch to see through.
yeah that's what I reckon.
unless the window tinters aren't allowed to do that or something...I have no idea..
i've already arranged it with the boss of 6 star solutions, as the company i work for contracts them out to do window tints and detailing etc. He said i can go as dark as i want(and he'll do it), even ambulance/limo grade....
i've driven an R33 with dark black tints at night before, was a bit tricky but was still ok.
Fatz... that's why you mount spotties on your boot or on your rear parcel shelf thingo ;)
Good if some prick is hi-beaming you or tailgating you, just hit em with the spotties.
Actually, that's quite a good idea, good work jago *high five*
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
