ok, here are a few, mainly cheap shots, oh and some cars too.
http://www.pbase.com/deesh
i just realised, pbase resizes them, so if you click original down the bottom, u get the full size 1024x768 pic.
you can also see the crappy digital zoom on a couple.
  • Replies 143
Originally posted by macka
I told her i dropped my credit card in the engine bay...
Ahhh macka , it's all good , so far your are da man !! and I am REALLY pissed off that I had to work all w/end.
Last year , I was in the AFARCC spa with two guys and three chicks and I wish I had a camera then !
Cheers Ken..
I must say the babe in the first 2 shots credit goes to GtstVSPEC for pointing me in the right direction.....
Talk about timing!! she was posing for a car magazine photoshoot and i jumped in just in time for a cuttla good shots..
Ok here are mine but...
I have to agree on that there inst nice chicks on about on sunday :) most of them were skanks so I didnt want to take shots on them...
Not worth it.
I have to admit that Mack did good job and I like them, he earned my respekit! :)
This is one of my best...
cheers
Joe
Originally posted by Pva_Glue
ok so Which one of you are you?
Macka and Shannon I know...
which one is GTS-T Vspec?
only if I knew which one was post whore! :lol:
Hes not there just look for sideburns in the crowd :)
Guys in pic
Fatboy,Macka,Daniel,Osc@r
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
