City Rsl Pi$$up - Thursday Night 8/9 - Be There!
keen to travel home like this tomorrow night?
want to join us for a night of intellectually stimulating conversation regarding the latest pressing issues in the world around us? well come to the rsl tomorrow night for drinks with some of sydney's finest gentlemen.
I have found my members card so we're back to good ole cheap prices.
$3.05 per pint!!!
so get there from 5pm onwards. join fatz, beer baron, and my good looking self at:
LEVEL 4, SYDNEY CITY RSL (george street near cinemas)
if you get lost on the way (No not on the way home!), call me on 0402 287 773
cheers, MARK
  • Replies 91
Come and discus the finer points on why blitz never comes....
is he gay, does the rsl not sell his favourite girly drink, why does he like g strings, how many men has he fantasised about in the last 3 minutes, when is he going to get a r31 and become a man
haha, b-man, you wont beleive it but on my pc your avatar doesn't work? maybe we are just not meant to be :)
i heard blitz is a bit camp...
actually it was mark who told me that. i wonder how he knows?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
