hey mate..
i'm in the same position as you..
i've gotten some other quotes though, try unigroup @ girraween.. they quoted me about 50 - 60 per hour.. takes about 5 - 6 hours..
and try sonny and kemp at ultra tune in smithfield..
Theyre on nissansilvia.com - go to the new south wales forum and there should be a sticky thread called INTERCOOLER PIPING or something like that.
check that out and send em a PM
cheers.
I did my own install, and also another persons the other day for $250 and they supplies the pipework, clamps and brackets. Its approx 5hr job, as you have to do alot of angle grinding on the support bar which takes the most time.
You also need to modify the front bar, to fit the bar back on, hence cutting back some of the plastic.
With the right tools and some nice space, not too hard to do :D Today I had to dismantle a FMIC for compliance purposes, and replace it with the stock cooler, that basically felt like more work than an install... hehe
would not be a pretty if i tried to do it myself
:D
Ahhh i c, its really not that hard to be honest.... If you want, I can do it for the same price as I charged the other guy to install his... You basically just need to supply the pipe kit for ur FMIC...
Do you have an aftermarket front bar????
hey i have just bought a 3.5 inch xforce turbo back system and a fmic for my 33, was wondering if anyone new any places around hills area where could get fmic installed
have been quoted around 500 for install from unique autosports, is that the price ill be looking at?
thanks :D
Hey mate,
I got the same exhaust system.....is it the one with the combined dump and front pipe?
My one is a single dump & front pipe and it seems to keep coming loose from the turbo.....ive had it tighted 2 times already, same thing happens.....
let me know if you get the same problem......hopefully not.....
Stel
yeh i have an fm style front bar
I (and other SAUers) strongly recommend MRC.
Very helpful, explains everything and high quality work.
tell em the price son, the price son!
eventually, when i get the FMIC done, i wanna Eff the piping off and move it to the other side so it comes up the OTHER side of the engine, then across the top, so i can relocate my pod in the lil stock cooler box thingo on my front passanger side thingo. ;)
Thing to the thingo thingo.... Hrrrrmmmm Anyhow, you can run CAI when it routes the piping over the engine fan.
seeing as your in the hills area give castle hill exhaust a go.
they did my complete front mount, plumbing and exhaust and total cost ended up being $1600.
they made and fitted the lot in about 3 days and do good quality work, im sure the fact they dont have to make anything up would make it alot quicker and cheaper.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
