hey everyone sorry to stuff u all around but i have been of the net for ages it seems.
So this is what it will be.
sunday the 25th of september
meeting at 8am at bella vista bp on old windsor rd.leave at 8.30am.
Stop at maccas lithgow for a coffee or what ever people want.
After that will leave and head up to the mountain for photos,laps etc
by this stage it will prob be close to lunch and will head into bathurst for a meal or drink etc
so just put ur name down in the post if u are coming cheers kane
https://www.sau.com.au/forums/topic/87020-mount-panorama-cruise/
  • Replies 128
Posted Images
there is already a few guys from my down going to come,so it will be real good fellas...come on come see the wonderful mount?can get some real good photos of ur car up the top wityh all the good fews and shit so all u blokes and chicks tell us ull come
Hihi~~
i wanna come ,but i m not quiet sure about the meeting place...
Best way to get to the cruise is either via the M2 (for city / northern suburbs people):
Go to the end of the M2.. this will be OLD WINDSOR ROAD... turn right onto old windsor, and follow that for a few KM's... you'll see the BP / Maccas on the right hand side of the road... there's a set of traffic lights there you can use. It's just after the Norwest Blvd intersection.. it's the first BP you'll see.
For people that want to use Cumberland highway, it's very similar... at the end of Cumberland highway, turn left onto Old Windsor Road... follow that until you see a BP, and it's the same location listed above.
If a lot of cars turn up, we will be in the McDonalds car park. If anyone is unsure on the directions, feel free to shoot me a PM and I'll give you my mobile number.
This meeting location is best because there's not as many traffic lights after that, so it's easier to keep us together as a group... I'd say we will meet up again at Windsor McDonalds to ensure the group is together.
Cheers,
Tommo.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
