I know this is not related to this topic. I wanted to let you know that I am a fully qualified and Licensed Motor Mechanic and I am available to work on Skylines, Silvia, 180SX or any other make of car for that matter on the weekends and evenings etc. I am employed full time by a reputable tuning shop. Experienced with RB20DET, RB25DET, RB26DETT and SR20.
Can supply and fit all aftermarket parts, electronic boost controllers, aftermarket fuel pumps, high flow fuel injectors, aftermarket fuel pressure regulators, turbo's, camshafts, adjustable cam gears etc etc the list goes on. Can also remove and replace turbos on Skyline GTR RB26DETT.
Also general servicing, spark plugs, timing belts etc.
If you use my services, it means you will get the exact same quality of work you would expect from a reputable workshop but at about half the hourly rate! This is a substantial saving.
If you are interested or you know someone who might be interested email me at:
[email protected]
Cheers...
Those look f**king awesome! How much would they be you reckon? How many mm wider are they?
they are currently $650 in NZ, obviously + postage etc will all add up. but the ones made here should be cheaper, plus u wont have the same issues with postage. im mainly interested in bringing one set in so i can duplicate it cheaply as i'll need a few sets a year.
Just got some new shoes for the 4 door. Didn't want to spend a fortune and these popped up at a decent price. Its not that tough yet but slowly getting better.
Weds
17x8 +6 215/45
17x9 +13 215/45
Could do with a 6mm spacer all around and some serious low (the height really lets it down). Unfortunately can't go uber low as the roads to work everyday are quite hagard and getting it on/off the trailer every track day is all ready a hassle.
  • 3 weeks later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
