ProLumen Tech Corp
We are a professional HID head light and related products manufacturer, for the past 6 years, we have been concentrating on HID lighting products in R&D, manufacture and quality improvement, as a result, our factory have been certified by ISO 9001 and TS 16949, our ballast systems have been approved by E-Mark (E-13) both for 12V and 24V systems.
By now our products have been in the markets successfully all over the world for 4 years, they are supplied to car manufacturer as OEM parts in Taiwan, which means we are beyond the "after market" quality, as for the HID conversion kits, each kit has to pass some very critical testing such as durability, reliability, bulbs light-colour matching..., etc for over 4 hours before they could been delivered to our customers, thus the defeat rate is held under 1%, and that's why our USA ,Japan and Taiwan customers rank us high reputation, with the best quality, competitive price and delicate customer service, you will have the total solution from us.
1) These kits are for off-road use, it is the owners responsibly to ensure they adhere to state and government regulations.
2) These kits are to be installed by a licensed Auto Electrician or similar. This is at the buyer’s expense and responsibility.
3) These kits are not waterproof, any water damage will void warranty.
4) The bulbs need to be handled with a lot of care, clean any surfaces touched with bare hands with spirits and allow to dry.
5) The buyer accepts all responsibility after purchase.
6) No refund or exchange (No Exceptions)
7) 1 year limited warranty, but goods need to be shipped back to Taiwan. If the unit is deemed faulty and ProLumen agree then all postage charges are payable by ProLumen.
These kits retail for over $400 US
$320 delivered anywhere in Australia
The delivery time is approximately 5 – 10 working days depending on what is being manufactured at the time. Please understand that we are dealing directly with the manufacturer and larger orders take precedent over us.
This kit has been fitted to a 2002 BMW 320Ci for the last few days and the results are very impressive. 6000k is very very white with maybe a slight hue of blue. It is much whiter and brighter than Factory Xenon lights such as the Honda Accord Euro.
If you don’t want your HID’s this bright then you can order 4300K.
Orders are being taken now... So please email [email protected] with your name and what type globe you need and what colour temp you require.
Cheers
https://www.sau.com.au/forums/topic/87083-prolumen-hid-kits/
You'd need to buy 2 kits if you wanted to do the high beam as well as the Skylines are 2 seperate bulbs.
But honestly, you wouldn't need to do the high beam with these, they're bright enough as it is. In fact you would barely need to use high beam
I'm looking for a kit for an R32 GT-R as I have recently had one of the round projector style lights (lowbeam) fail....
is this kit a replacement for these?
and if so do you have any in stock?
thanks....
For those of you who have H3c H3b globes, please note H3 should fit fine. Please read below
I only fitted one side but it fits perfect. No mods or anything, I'm
not so sure if there is a difference between H3 and H3C now...at least
I can't tell the difference. Very easy to fit and no modifications. If
they've got questions get them to PM me on SAU (CerealKiller).
Nathan.
On 14/10/05, <[email protected]> wrote:
>Hi Nathan,
>Can you confirm the H3 I sold you fits in the R32? I know you wanted a H3C.
>The reason I ask is that I got a few R32 SAU members who want a kit but are
>not sure if the H3 fits.
>Cheers
>Gehan
Do u have any on you at the moment. Im assuming they will fit easily into my R33 gtst? if so i can pick up now if you got them. Give me a call on my mobile 0410 580 010 and ill come pick one up tonight if everything is ok.
Nathan.
>Hi Nathan,
>Cheers
>Gehan
The main difference between H3 and H3C is that the H3's have a single pin and the H3C's are a dual pin.
H3 are generally for high beam use in the R32 GTS-t as the globe surround is earthed. (meaning the single pin is for your 12V+ supply)
The H3C is for low beam use has 2 pins on the globe. One for 12V+ and one for 12V-
I can't really see a problem with a HID kit in H3 for low beam except that the globe size does differ and can cause problems. EG: aligning the globe and getting it sit correctly and obviously the spring that holds it in place.
Would be interested in one of these but for the price of the unit and not being water proof sort or deters me a little.
Cheers B
just an update, H3C and H3 won't fit. I got the globe type wrong on my projector lamp as I was under the impression that all R32 projectors are H3C (as mentioned many times on SAU). It's not the case. Some projectors are H3 (ring around the projector), H3C (non ringed). Wiring wise you'll have no problem, but the issue is that the H3 globe doesn't fit in the H3C socket.
Anyway, the HIDs are brilliant, a must have for those who drive a lot at night, especially R32 owners.
You sort of lost me there CK???
I am running H3's instead of my H3C's at the moment (not as HID) but for my high and low beams as it was the cheapest way to get better lighting.
Is this just relevant for HID conversions and not the stock assembly???
Cheers B
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
