Hi,
Just recently I test drove and fell in love with a Skyline I'm looking at buying, but to be honest, I have no idea what I should be paying. Looking on Ebay and the Trading post etc, it the price sounds about right, but tonight looking through your forum, I'm begining to think I'm way paying too much...
Forgive me, but can anyone tell me what they would expect to pay for a car like this???
THANK YOU !!!
Vehicle 1996 Nissan Skyline R33 II GTS25-T White 5 Speed Manual Coupe
Body Colour White
Trim Colour Black
Doors 2
Capacity 2.5
Gears 5 Speed
Gearbox Manual
Odometer 67581
17" Nismo Wheels, Body Kit, Exhaust System, Recaro Seat.
Vehicle Options:
» ABS Brakes » CD Player » Electronic fuel injection » Radio
» Air Bag » Central Locking » Power Mirrors » Turbo
» Air Conditioning » Child Restraint » Power Steering » Window Tint
» Alloy Wheels » Climate Control » Power Windows
https://www.sau.com.au/forums/topic/87362-help-information-on-r33-gts-t/
check the interior, as in; steering wheel, hand brake cover and gear stick for wear as it should still look brand new on a car that 'supposedly' done 67k. Not many skylines around that have genuine kms. But may be worth paying a little extra if it is genuine.
first of all, i doubt the kms is right as it is a 9 yr old car. Try lookin at the odometer on the dash board. Are the dials all straight? If not, that means the dials have been fiddled with and clicked back.
I guess an R33 GTST S2 in good nick will cost you about 18-20k depending on the mods the car has as well. This car with recaro seats and exhaust system might be about 21-22k i reckon? Good luck! :D
Edited by fLipKnot
I guess an R33 GTST S2 in good nick will cost you about 18-20k depending on the mods the car has as well. This car with recaro seats and exhaust system might be about 21-22k i reckon? Good luck! :(
im lookin at 1 that is basically the same. 96 GTS-T just over 100,000km (so not totally un beleivable)....ummm exhaust, and pod i think...boost gauge and thats about it...
fresh respray (its black) $18k.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
