  • Replies 58
Hmm NUR you say...
http://www.j-spec.com.au/list/3954
aaaand...
http://www.j-spec.com.au/list/3733
If you want to spend a smidget under 200k, we could just get you this one:
http://www.j-spec.com.au/clients/index.php?ID=1200hp_BNR34
or
http://www.j-spec.com.au/list/3899
or
http://www.j-spec.com.au/list/2504
but you know... you could always get one locally so you can test drive it first :wub:
It's an M Spec Nur = the pointless one.
GTR's aren't supposed to be a "luxuary" car. Soft suspension and leather seats - pffft!
Ahh you mean the ones with the ripple control suspension that hands the VSpec its ass on real roads, and Brit journalists that hated the V Spec GTR34 decided this was better than the TT Porsche Carrera 4 they were testing the same day by up to 20kmh through certain corners.........
Jap Hard suspension sucks. Compliance and control is the key.
I actually think it's a lot overpriced but give it another 2 years and stock M Specs will be about 60-70, then I'll buy.
Farking work proxy.
I get this shit
Warning: preg_match() [function.preg-match]: Unknown modifier 'n' in /home/jspecau/public_html/list/index.php on line 5
try it now n tell me if it works :)
ferrari is the winner for me
although i love my nissans and jap cars altogether a nissan is just another jap car but a ferrari is a ferrari its a totally different ball game
even our old 308 GTSi is still an awesome car 20 years on
damn straight it would be a smart cruiser. People dont buy ferraris to cane them. They are for Class.
But its just my opinion that i would prefer a ferrari over a nissan.
WHAT!? They aren't just for looks. When I buy my Ferrari, I will be caning it. After all, that is why they were built. :) But I wouldn't buy a Spyder anyway.
My best mate's brother in law has(had) a 360 and he absolutely canes the pants out of the thing. Unfortunately he recently crashed it.
That is my ultimate GTR. When can you get it here? ;)
spot on imo...id definitely take the ferrari
550 maranello....mmmmmmm
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
