will a custom 3" catback exhaust (including a 3" hi-flow cat, everything else res/muffler are 3" straight through) be an ok option instead of forking out a grand and a half for a brand name one?(the custom job was estimated at $800) im hoping to un-restrict the exhaust system without the damn droning sound that you normally get with the brand name aftermarket systems. i was considering Greddy Power Extreme II system, anyone running one of these? sound good, not too loud?
Edited by RyanN
https://www.sau.com.au/forums/topic/88006-r34-gtt-3-custom-exhaust/
Hi Ryan,
Short answer: "Yes".
Long answer:
The jig-made Jap stuff generally seems to have better looking welds than custom
stuff. There are also generally fewer of them (most exhaust shops don't own
a 3" mandrel bender so they will make a custom 3" exhaust out of 3" mandrel
bends so there are more joins)
There's a case to be made for 'less joins' and 'smaller welds' in terms of flow;
but I'm guessing that the difference is minimal if measurable at all for most cars.
"Droning" is a subjective thing - every exhaust will have a resonant frequency
(and most of them a corresponding RPM that it sounds 'louder' at). Hopefully this
frequency is not at cruise RPMs. Unless you just mean 'too loud generally' -
in this case, adding more mufflers (or using more effective ones) will usually
be the answer. It's a tradeoff between flow and noise - a system that flows
the best is usually the noisiest. I haven't seen the muffler yet that added noise
restriction without also adding flow restriction. If a system is custom you should
be able to add/delete mufflers at will, and your exhaust shop should also have
a pretty good idea about what a given system will sound like _before_ they make
it. Tell them what you want.
The best thing to do is go to a cruise or a track day for your model car, find the
sound of something you like, and see what's under it. Ideally, get a ride in it
if the owner's agreeable so you can hear it at different RPMs. Try find something
that's street legal :P
Regards,
Saliya
thanks for the replies; im awaiting an email for a price on the Greddy Power Extreme II system for a 4dr skyline as i think the website listed the 2dr price which was $799; about the same as the custom which would be alot easier since i wouldn't lose the car for a day. Hmmm, siliences are an ok idea but a cop traveling behind and seeing it will most likely pull me over and canary it, the idea behind the custom exhaust system was to make it look as stock as possible - even with simular dual tips; i'll have to wait till monday for price estimate on the brand name system if it too much i think i'll go with the custom system.
Edited by RyanN
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
