  • Replies 41
franks
usually most mechanics can do fleet servicing, my car is a fleet pruchase as well, and I just tell the mechanic before hand, they ring your fleet company, and charge the service to them!
peice of cake.. I even got some mods done on fleet card!
service? whats in a service really...
maybe sparkies, but prob not if youve had any moda done lately cos you would have already changed em...fluids, oil/filter, thats about it
all other stuff u would b changin with mods anyway..or just upgrading stuff for more hp, if ya unsure just get a mate who knows a bit about cars and do those simple things...
they might charge to chang this and that and but u might not need em, and if they do change other stuff its prob not gonna b top quality stuff so just upgrade those parts to quality aftermarket stuff when u put more mods on ya car.
woa!!! i think you got ripped ... u could have done all that yourself for around $200 including the plugs. None of that stuff is difficult and they're the same as in any other car.
But i've been there before so i can't talk, but that is why i try and do those service things myself these days unless there is a problem.
1. Warm up car slightly so oil is warm
2. Get oil pan ($10 or so)
3. Jack car up slightly so angled towards oil plug
4. Pull oil drain plug - watch old oil drain out into pan until done
5. Replace oil drain plug
5. Unscrew old oil filter (its the big pod thing sticking out the bottom left of engine). Its usually just a hand twist job
6. Screw in new oil filter in place.
7. Pour in 5L of good xxxx oil (whatever u prefer) that you picked up for $20 less than they just charged.
8. Drive around, feeling good that u saved $150 and knowing you did it yourself. Charge your mates $50 labour to do the same :)
1 hour job at most.
yeah, i had to give it ago coz no other workshop i know of takes fleetcard and im taking it down the coast this long weekend and i was pushing for time...
i did all my oil changes myself on my previous car, but thats about all i could do :)
i also wanted to check my spark plugs to see if they were fouled, consequently they were and they were replaced. i also wanted a full check on everything else coz im going away this w/e.
sometimes i think we take for granted time and expertise. i'm no expert in cars, i know a little, but i would like to think they would have a higher probability of spotting something wrong and fixed it on the spot. if i did it myself, i would've almost definately missed it and not fixed it!
meggala you missed spark plug change and supply, but i agree, it is a little expensive.
Frankster - When I first got my car serviced at Hills it didn't cost me much. In labour it was around $100 for around 2 hours which is average I'd say. I have bought the following stuff myself at that service or over time and as far as I can see its the main things you need:
Engine Oil (Whatever flavour you like)
Oil filter (Genuine Nissan)
Fuel filter (Genuine Nissan)
Brake Fluid (Motul Dot5)
Gear/Diff Fluid (Nismo)
Sparks (NGK)
Long Life Radiator Coolant (whatever hills put in)
As far as I can see these are most of your wearables. There are other small things you may need to replace everynow and then including some of the washers and there are routine maintenance things you may have to do like lubricate this and that. I'm not sure if $600 for that was a good deal however I guess you get fleet and also you get a pretty piece of paper that is usefull when it comes time to sell.
I like down the bottom
Comments
Front Tyres Good
Rear Tyres Worn
Nice work franks.
Check out other workshops.. thety should all be able to do fleet discounts, even ring your lease provider, they may have a listing of workshops that accept their card.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
