just found out about this twin turbo filtration units for 999 automotive. has any used them or heard anything about them? looks to me that they would have to be in a box cause the cops would have a field day with them. they are to suit gtst's and they sell for $155 with adapter and delivered/
some opinions would be much apprieciated
cheers
Edited by ICER33
https://www.sau.com.au/forums/topic/88055-new-type-of-pod/
yeah i dont think they will have any impact over a normal good single pod ..
get an apexi dual funnel filter from negun...$90 delivered and has been proved as one of the best on the market...
be easier to get a single into a box than that little monstrocity....
https://www.sau.com.au/forums/topic/88055-new-type-of-pod/#findComment-1589431
Looks like a product for the person who's already bought a cheap imitation GT-R front bumper and rear wing (with the appropriate badges) for their GTS-t, and is ready to take their automotive masturbation to the next level.....
https://www.sau.com.au/forums/topic/88055-new-type-of-pod/#findComment-1589503
Where do you get it ??
/end Knock and Kirby's add
http://www.fabre.com.au -- their shop is in Sydney if you feel like getting it in person.
SK: Do you forsee a limit to the stock airbox arrangment (with a good filter like a Pipercross)?
https://www.sau.com.au/forums/topic/88055-new-type-of-pod/#findComment-1589596
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
