  • Replies 40
haha, i wish bro... never be that good.. how did i do it, well i used PS 3.0
cause i dont like 7.0 for some reason it makes all the pics on my computer go real small.. and way i just did what you said, but took a shit load of time cutting, its the realist i can get it. black is so damm hard to bend new clours in.. im going to chuck a few birds in now...lol
You think black is hard? try white!
well i did a quick job on my mates R33 GTS-t... I think i like green on his ride, he wants me to paint it for him for real now..... NOOOOOOOOO..
any way this it it ;)
Edited by kezza
I still think black is the hardest to change, this is a pretty quick and easy job, i tried to get like a blue pearl with the orange, you can just see it. I like Kezza's one better tho
Edited by mick5051
haha, man.. you know your the king bro. that pearl looks hot..
any way this it it  :(
You forgot to untan the piece of space in between the wing.
Otherwise very nice job :)
Here's my Effort... not the greatest, just changed the colour to some crazy kind of gold - All that's needed now is the GLDMMBA licence plates! :D
I've also got some interior pics from a 32 GTS-T that I modified the interior colour of. I've pretty much gone right through the colour range to see what colour I want do trim my interior - thinking tan suede at the moment, but open to persuasion...
Thanks for looking.
Thanks for looking.
yeah man.. looks good.. but funny on the roof tho. but yeah nice job.. love R32s..
Thought I would attach the interior pic that I used, and the result I got. If anyone has similar interior pics or cars and they want to see them a certain colour, e-mail or MSN me the pic and tell me what colour you want it - doesnt take too long to do.
1803_2mg.jpg is the original pic I got off the net, the other two are different colours I did. I like the yellowish one for my R32 GTS-T (Being burgundy), but think that the purple would be sweet if anyone wants to respray a 3-2 in midnight purple...
At any rate, enjoy!
any way this it it  :O
damn man you did a sweet job on naths car....looks unreal!!!! :D:D
when you gonna do my baby :):D
hehe yeah thanks mick... i did get what ya ment tho! I did another one thats a bit more detailed... hope ya like  :O
looking good...really like how you made this look but not too sure on the colour red.
i think i love it too much for it to be any other colour than black :)
damn man you did a sweet job on naths car....looks unreal!!!! :D  :D
when you gonna do my baby  :)  :D
:) thanks man.. If ya want i would love to have a go at your car. send me some nice clear pics and ill have a play :D
E mail them or jump on msn and send some pics, add me ([email protected])
Thanks man :lol: i have to say black is a sweet colour.. red looked ok tho. I did it in blue as well, and doesnt look too shabby!
Getting some real paint work done on monday, just the front bar getting painted again and the side skirts and pods. she should look better then. DAMM KIDS AND BIKES.... :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
