wow a 1.32ar for the exhaust is pertty big man, im guessing it will hit full boost around 5rpm+. thats if ur engine internals are stock. best way to go for an rb25 is a hks 2530 bb turbos. they spool up very quick and they have balls to
the real question is why match a 1.32 AR exhaust housing with a .64 compressor housing? doesn't seem like a good match to me. it will take ages to spool up, then when it does will instantly run out of ability to compress any more air... not good.
Actually the combo is pretty standard (and works) for a truck or a rotary engine.
yes. But is extremely usless on a RB25. (Which is what he asked in the first place)
I wouldn't even put a 1.06ex housing on a RB25..
Oh, and if it was fitted it would probably make bost at around 6000rpm in second, and maybe 5000rpm in third.
I have no idea how the car would react. I suggest you get rid of it and get a GT30 or something.
Edited by The Mafia
Thanks Ash
The Mafia: If you bothered to read the whole thread you would have seen my previous post, saying exactly that :(
But here it is below, just for you:
I stand corrected  :lol:
Either way, pretty useless on a rb25  ;)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
