  • Replies 322
Posted Images
  • 3 weeks later...
I bought a bunch of handling gear, waiting for it in the mail still.
after I get my mechanic mate to install it all, can I just take it to any alignment guys to get it all set up?
Edited by noise
Yep, any decent 4 wheel aligner should be capable. The recommended alignment settings are in the first post of this thread.
:rofl: cheers :rofl:
  • 1 month later...
Hey sorry am a little confused with the prices, will adding up all the prices for the individual items on your list give me the total? Just say I had a stock R34 GTT and pretty much wanted to buy every little part you could offer me, how much would I be looking at, minus the cost of installion?
I have HKS coilovers with a ride height of 330mm form the center of wheel to guard. Problem is, my camber is at -2.47 RL, -2.09 RR, -2.3 FL & -1.44 FR. What would be the best way to fix this as it doesn't look like the whiteline camber kit adjusts enough. Or will I have to raise my car up a bit.
Cheers
Hi, assuming you can use your standard tops, bump stops and bump rubbers and you don't need a front braces (it should already have one), prices as follows;
Front springs $144
Rear springs $144
Front Bilstein shocks $486
Rear Bilstein shocks $486
Rear adjustable stabiliser bar $219
Front adjustable stabiliser bar $219
Front camber kit $277
Front caster kit $115
Rear camber kit $118
Rear subframe alignment kit $110
Zero freight (order is over $500)
Sub total $2,318
Less 5% extra discount (order is over $1K) $116
Total $2,202
Note; that is with adjustable stabiliser bars, let me know if you want fixed rate bars and I will amend the price accordingly.
:P Cheers :D
Cheers
Hi, is that front or rear height and camber?
If it is front, then the front camber kit will bring it baack to the recommended setting.
If it is rear, then you will need 2 camber kits to bring it back to the recommended setting.
:P cheers :D
PS; 330 mm is really too low for good handling and ride comfort, around 350 mm is the lowest I would recommend.
^^^ What he said.
I had exactly the same setup (HKS coilovers, 330mm ride height) and the difference after raising it by ditching those damn things was pretty huge. I've since taken the car on a track and it handles great.... :D
Height is 330mm all round, the camber is both front and rear(RL=rear left, RR=rear right etc) maybe I will wind it up to 350mm then. Should that take the camber back to acceptable or will I still need the camber kits. Also would I need a wheel alignment If I just raised the suspension, I assume all the other settinfs should remain the same.
Cheers
Cheers
-2.47 RL
-2.09 RR
-2.3 FL
-1.44 FR
Raising it to 350 mm should remove some of the static negative camber.
The problem you may still have is the differential side to side.
1. The 2.47 on the left rear and 2.09 on the right rear, will decrease but you may still have the 0.38 diference side to side. That's almost tolerable
1. The 2.30 on the left front and 1.44 on the right front, will decrease but you may still have the 0.86 diference side to side. That's a lot. Some people use more camber on the left to counteract the drift to the left caused by the slope into the gutter of the road's surface. This has the downside of increasing tyre wear on the LHS front.
A superior answer is to have more caster on the left front, works just as well exept it has no downside.
Since it has less camber on the right both front and rear, I suspect a height difference side to side. Have you checked that?
:unsure: Cheers :)
Yea, front right is 5mm higher than the front left and the rear right is about 3mm lower than the rear left. I suppose I should get them all the same first. I might raise them all to 350mm first and get a wheel alignment to check. What would the max camber be before you look at getting camber adjusters. I would only do about 7000-10000km per year.
Thanks for your replys.
how long will this group buy be on for and how much would shipping be to NZ
Cheers
Cheers
At 350 mm front height, most R32/33/34's don't need front camber correction, it usualy ends up around 1.0 to 1.5 degrees. At 340 mm rear height, most R32/33/34's do need rear camber correction to get to the target 0.5 to 1.0 degrees negative.
You should be able to buy the necessary camber kits from your local Whiteline dealer in NZ. If you have no joy, the postage is around $50 from Australia to NZ for the front and rear kits.
:D cheers :)
PS; remember every car is different.
  • 1 month later...
These settings also go for a non turbo? Sorry, didnt see this question asked already...
Yep, same suspension, very slight weight difference.
:happy: cheers :P
not sure what model car you are talking about, but for an R34 the turbo and non-turbo suspension is quite different.
R34GTT suspension has balls at the front and forks at the rear. (Like the R33GTR)
R34 n/a has balls at the front and balls at the rear.
Correct, but the questions was settings, not shock absorber configuration. For the R34GT (non turbo) I use R33GTST rear shocks.
:( cheers :)
Bilstein Australia have recently managed to tag onto a small production run of R34GTT and R34GT shock absorbers that was done for the Japanese Bilstein agent. They also managed to have the valving done to our specifications as per the previous Group Buy sales.
These shocks arrived via airfreight today. So there are currently several more sets of R34 Bilsteins available for anyone interested in the Group Buy kit.
:( cheers :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
