  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
heres an idea
Open a .txt and just write all ure bs in there.
Its not the content its the attitude. Double posts are for noobs and tools (no offense) there is just no point to post 2-10 in a row especially when ure not saying anything but babbling crap. Sorry im gonna say it, get a life :(
Originally posted by Boostzor
heres an idea
Thats ok, i am not offended. I would not have post-whored like this except, so many others have done it [this is where the idea came from! bad excuse but "i didnt start it".
Yeh trouble is i think i did start it. i think when i hit my 1000th post vspec got all excited and really turned it up. this is like "the island of doctor moreau" all over again adn u guys are the monkey men :lol:
Originally posted by nismoR34
so all of your 1081 posts are legitimate / bona fide posts then Boostzor? I doubt it :uh-huh:
You were a noob once too, correct me if im wrong!
Never said that, some of the pointless post are what makes SAU good fun but 10 posts in a row?? i dont think so, not fun for any1
Originally posted by GTS-t VSPEC
I thought the whole idea behind whoring was to get as many posts as possible down.
See'ya:burnout:
what he said.
boostzor, if you did start it, then you have opened up a can of worms...:jump:
Paul, how long have i been here? how long have u been here? i register like 6mnth or something b4 u and ure post count is wayy higher than mine. u have posted like 300 times in the last week or 2. Getting beyond the joke wouldnt u say?
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
