  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam,
Screamer pipes are for external wastegate turbos. With a stcok turbo the best option is to get a dump with separate internal watsegate pipe. You can get these custom made quite cheap at Genie's in Myaree.
Kym,
If you don't get a 13, then it is you and not the car. rev210 sure knows how to drive, but you won't get any respect if you don't drive it yourself.
See'ya:burnout:
Whats wrong with my whoring, whoring, whoring threads??
There just as pointless as the other shit that gets posted. Why not point out paul instead of constantly giving me shit!! I'm sick of your comments. Obviously you have somethin against me although never meeting me, but i'd appreciate it if you just lay off the constant bitching about me, cheers.
P.s, Boostzor, cypher is good. There all top blokes.
Originally posted by GTS-t VSPEC
You could do it but why? The amount of flow on the stock turbo is so small as to make an externally venting wastegate pointless. If your after wank factor then do it, will match all your stickers, haha.
See'ya:burnout:
hahaha
i just wasnt sure if there were any performance gains to be made or not, but seeing as each sticker adds 5hp, what would a screamer do?? at least 20hp, hahaha.
i wasnt gonna get one, just asking about them and there gains if any
Thanks Joe , that made it a nice quiet day in Whoretown.
Bet you pwptf and Hicks were beside themselves with grief over there inability to post large quantities of cr*p:D . hehehe
Cheers
Ken
Hey Ken, that is unfair, all the stuff I post here is brilliant and insightful, you just need to read between the lines.
Thanks for reopening Whoretown, give me the key I'll look after it. I'm sure with this spate of lockings we will all be on our best behaviour.
Love GTS-t VSPEC
See'ya:burnout:
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
    • @GTSBoy iam not a mechanic so what could typically gone wrong? It can help my mechanic...maybe he just forgot something or something like that that could help. Yeah i thought. I took a LONG time to search for the right one. Yes i read about all of that and i give him a call about that. I look at those slave/master cylinders and they are not that expensive so i will be buying them anyway just to be sure.   @DuncanYou think it can be short? I double checked if that was a right one(it came with the clutch kit) Ok i will give him a call. Hope it is some sort of "little error" and not some "yeah the gearbox needs to go out" one
    • Temporary. Sorry about the inconvenience while we sort some issues.
