  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam,
Screamer pipes are for external wastegate turbos. With a stcok turbo the best option is to get a dump with separate internal watsegate pipe. You can get these custom made quite cheap at Genie's in Myaree.
Kym,
If you don't get a 13, then it is you and not the car. rev210 sure knows how to drive, but you won't get any respect if you don't drive it yourself.
See'ya:burnout:
Whats wrong with my whoring, whoring, whoring threads??
There just as pointless as the other shit that gets posted. Why not point out paul instead of constantly giving me shit!! I'm sick of your comments. Obviously you have somethin against me although never meeting me, but i'd appreciate it if you just lay off the constant bitching about me, cheers.
P.s, Boostzor, cypher is good. There all top blokes.
Originally posted by GTS-t VSPEC
You could do it but why? The amount of flow on the stock turbo is so small as to make an externally venting wastegate pointless. If your after wank factor then do it, will match all your stickers, haha.
See'ya:burnout:
hahaha
i just wasnt sure if there were any performance gains to be made or not, but seeing as each sticker adds 5hp, what would a screamer do?? at least 20hp, hahaha.
i wasnt gonna get one, just asking about them and there gains if any
Thanks Joe , that made it a nice quiet day in Whoretown.
Bet you pwptf and Hicks were beside themselves with grief over there inability to post large quantities of cr*p:D . hehehe
Cheers
Ken
Hey Ken, that is unfair, all the stuff I post here is brilliant and insightful, you just need to read between the lines.
Thanks for reopening Whoretown, give me the key I'll look after it. I'm sure with this spate of lockings we will all be on our best behaviour.
Love GTS-t VSPEC
See'ya:burnout:
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
