  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam,
Screamer pipes are for external wastegate turbos. With a stcok turbo the best option is to get a dump with separate internal watsegate pipe. You can get these custom made quite cheap at Genie's in Myaree.
Kym,
If you don't get a 13, then it is you and not the car. rev210 sure knows how to drive, but you won't get any respect if you don't drive it yourself.
See'ya:burnout:
Whats wrong with my whoring, whoring, whoring threads??
There just as pointless as the other shit that gets posted. Why not point out paul instead of constantly giving me shit!! I'm sick of your comments. Obviously you have somethin against me although never meeting me, but i'd appreciate it if you just lay off the constant bitching about me, cheers.
P.s, Boostzor, cypher is good. There all top blokes.
Originally posted by GTS-t VSPEC
You could do it but why? The amount of flow on the stock turbo is so small as to make an externally venting wastegate pointless. If your after wank factor then do it, will match all your stickers, haha.
See'ya:burnout:
hahaha
i just wasnt sure if there were any performance gains to be made or not, but seeing as each sticker adds 5hp, what would a screamer do?? at least 20hp, hahaha.
i wasnt gonna get one, just asking about them and there gains if any
Thanks Joe , that made it a nice quiet day in Whoretown.
Bet you pwptf and Hicks were beside themselves with grief over there inability to post large quantities of cr*p:D . hehehe
Cheers
Ken
Hey Ken, that is unfair, all the stuff I post here is brilliant and insightful, you just need to read between the lines.
Thanks for reopening Whoretown, give me the key I'll look after it. I'm sure with this spate of lockings we will all be on our best behaviour.
Love GTS-t VSPEC
See'ya:burnout:
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
