  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
See'ya:burnout:
Do the math. How many mm to one inch?
Match tyre width to rim width give or take 1 inch max, for handling.
rev,
I have 8" rims and 9" rims, I know what fits on them well. No-one wants a tyre that has to be stretched over the rim, it looks shit, and handles badly.
Adrian,
Yes we have camera's, so I suggest you leave that dog alone.
MrGTST,
Your meant to post the chicken noise. Tyr it again, the rules are simple.
See'ya:burnout:
hmmmm
as a expert nandos chicken griller
i should get this one easy!
Cluck Cluck
Bwark Bwark Bwark
(flapping of feathers)
ahhh easy does it
mr gts-t answered for ya by a true professional
anyone up for a drive tonight
i am bored nuthin to do!
adrian :)
rev,
See'ya:burnout:
Want your sidewalls to be straight without any radial roll?
Ah.. I see you want it to 'look good';)
say no-more!
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
