  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
See'ya:burnout:
Do the math. How many mm to one inch?
Match tyre width to rim width give or take 1 inch max, for handling.
rev,
I have 8" rims and 9" rims, I know what fits on them well. No-one wants a tyre that has to be stretched over the rim, it looks shit, and handles badly.
Adrian,
Yes we have camera's, so I suggest you leave that dog alone.
MrGTST,
Your meant to post the chicken noise. Tyr it again, the rules are simple.
See'ya:burnout:
hmmmm
as a expert nandos chicken griller
i should get this one easy!
Cluck Cluck
Bwark Bwark Bwark
(flapping of feathers)
ahhh easy does it
mr gts-t answered for ya by a true professional
anyone up for a drive tonight
i am bored nuthin to do!
adrian :)
rev,
See'ya:burnout:
Want your sidewalls to be straight without any radial roll?
Ah.. I see you want it to 'look good';)
say no-more!
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
